Old 03-20-2014, 09:48 PM   #1
Keynes OP
Oddometer: 14
Tiger 800 - SW-MOTECH heel guard & LeoVince Exhaust?
Just installed my LeoVince slipon exhaust on my Tiger 800 XC, and when I went to put the SW-MOTECH heel guard on, I noticed at the very top left it is hitting the exhaust pipe. It's not too bad, but it is definitely putting pressure on the new exhaust. I tried adjusting the exhaust as much as I could, but it really didn't seem to help.
Do I really need to worry about the thing putting pressure on the exhaust pipe, or is it no big deal? Anyone else run into this? If so, what have you done to resolve it? Put a bigger washer in place behind that bolt?
Keynes is offline   Reply With Quote
Old 03-21-2014, 01:03 PM   #2
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,566
I wouldn't let it touch. It will most likely rub a hole eventually. Can't you bend the guard enough that it clears?
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 03-21-2014, 01:11 PM   #3
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,806
+1... Unbolt the guard, place in a vise and bend
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 03-21-2014, 02:44 PM   #4
Keynes OP
Oddometer: 14
I wasn't sure if bending it would cause it to break at one of the joints, but I will give it a try. Thanks!
Times are GMT -7.   It's 01:10 PM.
