Old 03-21-2014, 04:04 PM   #1
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
Seized oil jet bolt
The bolt covering the clutch oil jet seems to be seized. Any tips on how to get it loose? Already soaking in wd 40 but fear destroying the head when trying too hard.
Torch is not an option I guess?
Verstuurd van mijn GT-I8190 met Tapatalk
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 03-21-2014, 06:50 PM   #2
gearheadE30
gearheadE30's Avatar
Oddometer: 877
heat can help. Make sure the head is cleaned out and your allen key fits well. Penetrating oil works much better than WD40 fwiw.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 03-21-2014, 08:12 PM   #3
dgjackson40
Oddometer: 253
Oil Jet Bolt
Have you tapped it with a small hammer. Rapping it pretty solidly several times directly down on the bolt may break something loose. Also have you tried tightening it before switching the ratchet and loosening it. Sometimes just a small movement of the bolt in the tightening direction and then swithing to loosening helps with any seized bolt.
Have you ever had he bolt and the jet out in the past? If not when you get the jet loose and if it doesn't come out directly I found that I had to use a quick shot of compressed air to get the jet up out of the hole. I thought of using sticky substances (silicone, grease, ets) on the end of a probe but that didnt work and I was afraid of getting the substances stuck in the hole. One quick shot of compressed air and the jet came right out.
The trail is the thing, not the end of the trail. Travel too fast and you miss all you are traveling for. Louis l'Amour
2007 KTM 990 Adv; 2005 VStar 1100 Sold!; 2002 GL1800
dgjackson40 screwed with this post 03-21-2014 at 08:18 PM
dgjackson40 is offline   Reply With Quote
Old 03-21-2014, 08:27 PM   #4
Iflylo
Iflylo's Avatar
Oddometer: 22
Oil jet bolt
If you can ,maybe ride the bike first and get everything warm.Try shocking it first with a bolt or punch ......good luck.
Iflylo is offline   Reply With Quote
Old 03-21-2014, 09:09 PM   #5
woodchuckexc
Oddometer: 801
can someone please post a pic of which bolt I remove to access the oil jet. I need to clean mine as its been a few oil changes since its been in for service
woodchuckexc is offline   Reply With Quote
Old 03-21-2014, 09:30 PM   #6
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,304
The bolt is out here, but this is where it goes. And, the tools shown here were, for me, the easiest way to unscrew the jet.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-22-2014, 06:29 AM   #7
Bowber
Oddometer: 178
A sharp knock with a punch and hammer usually does the trick, you have to do this with the KTM EXC's as well.
Having the engine warm may help as well.
Steve
Bowber is offline   Reply With Quote
Old 03-22-2014, 12:19 PM   #8
woodchuckexc
Oddometer: 801
Thanks for the pics!
Old 03-22-2014, 12:31 PM   #9
rattis
rattis's Avatar
Oddometer: 1,170
Thumb Violence, ultra violence and Beethoven
Just, as everyone else said, a smartish hit with a hammer should do it
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-22-2014, 10:13 PM   #10
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
Just grab it with a needle nose vice grips. It will snap loose easy.
"Son, you can't do both"
Old 03-23-2014, 05:29 AM   #11
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
soaking in anti seize oil right now, next: tap with the hammer. If that doesn't help, vice grip.
Riding it hot is not an option at this moment... bike is apart for maintenance
Has been out a few times before, until now, it was never stuck...
www.roeligan.net
Old 03-23-2014, 06:32 AM   #12
Fundy Rider
Where 2?
Oddometer: 244
You could always cut a slot with a small zip wheel or hand saw with some patience. After slot is cut just use a big regular slotted screwdriver.
Fill your soul everyday
Fundy Rider is offline   Reply With Quote
Old 03-23-2014, 06:34 AM   #13
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,872
Impact driver.
DELTATANGO is offline   Reply With Quote
Old 03-23-2014, 06:53 AM   #14
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
Got it loose :)
www.roeligan.net
Times are GMT -7.   It's 08:47 PM.
