Old 03-22-2014, 12:13 AM   #1
grant22 OP
grant22's Avatar
Oddometer: 476
Jump starting through battery tender Sae pigtails
Just thinking about the what ifs in the middle of no where. Has anyone here jump started a run down battery by connecting through two bikes' Sae battery tender plugs? Thx for any insight.
grant22 is offline   Reply With Quote
Old 03-22-2014, 01:16 AM   #2
6732cash
6732cash's Avatar
Oddometer: 161
The battery tender plugs on the dash will not have wires thick enough to jump start the bike you could have one bike running charging the other bikes battery through the plug but this will take time......
6732cash is offline   Reply With Quote
Old 03-22-2014, 02:19 AM   #3
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,971
Sorry,
What are tender SAE pigtails?
Old 03-22-2014, 04:40 AM   #4
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,888
We have a short one direct to our battery and it would be more than adequate as long as you were not cranking and cranking, you would have to make sure + and - were on the same page but it could work easily.
Trick would be to leave them connected with the charging bike running to boost a little power before trying the start.
These fellas gefr http://www.cycleterminal.com/sae-connectors.html
The cables come with different sizes / ratings
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-22-2014, 05:11 AM   #5
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Ohh Kiwi - I am not sure they would unless you only need a little boost. Last time I jump started my big girl I needed some pretty heavy cables (and connected it to a car battery).
I have found that if the battery is that discharged though, the bike is unlikely to run properly after starting and jumper cables are removed.
If you are using the SAE plugs, I would recommend leaving connected for a while before attempting to start, like the Sheep Shagger said.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 03-22-2014, 05:40 AM   #6
Mikef5000
Oddometer: 2,030
I have seen people melt the insulation off battery tender wires numerous times. It is simply not a good idea. If your battery just needed a little boost, it would probably work, but the only way to check is hook it up, and see if anything goes terribly wrong.
Look at the difference in wire size, between the battery tender plug, an the battery cables going to the starter.
I've seen some very heavy duty sae plugs, with 12 ga. Wire (much thicker than normal), which would be much more likely to work, but even so, still not recommended.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 03-22-2014, 06:01 AM   #7
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,888
Yeag agree with all the above, OP says run down, not dead battery and yes this will change things.
I know we can start ours on a run down battery through SAE cos we have had to do it, was not connected to another bike rather straight off another battery and although sluggier it started (luckily).
If it were flat I think you would be asking for a fire
We also push started Maya at 4000 meters in Peru, just enough grunt to start to wind her over, push, clutch, 1st gear, press starter fired into life
We got a new battery in La Sarena ..... no more worrisome days!!!!
Old 03-22-2014, 06:38 AM   #8
grant22 OP
grant22's Avatar
Oddometer: 476
Ok, you guys confirmed what I was thinking. Thx.
Definitely would let them just sit connected and give a slight charge.
I'm talking after someone left their light on and ran the battery down.
Old 03-22-2014, 08:03 AM   #9
folknride
Old Adventurer
folknride's Avatar
Oddometer: 682
(slight hijack)
Is there any problem/danger to electronics in boosting the 9X0 through the main power connection on the lower right side, with the ground on the motor. Much easier to get at than the battery.
folknride is offline   Reply With Quote
Old 03-22-2014, 08:14 AM   #10
dmn0507
dmn0507's Avatar
Oddometer: 352
No problem as long as you get a good ground.
Avoid ground on footpeg, the pin might be dirty and current will flow only through the spring (and melt after a few secs). Ask me how i know
dmn0507 is offline   Reply With Quote
Old 03-22-2014, 12:39 PM   #11
rattis
rattis's Avatar
Oddometer: 1,167
permanently
Connect a SAE jumper cable permanently, just lower your skiplate and connect it, or let it rest on the skid plate a pull it out when needed.
I surely loved my jumpers when my battery died up in Jujuy in Argie
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-22-2014, 02:38 PM   #12
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,971
Thanks for your reply
Old 03-22-2014, 02:43 PM   #13
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,983
Not heavy enough gauge for jump starts....just enough for trickle charging....no doubt about it......
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 03-22-2014, 03:43 PM   #14
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Originally Posted by folknride View Post
(slight hijack)
Thats what it is there for at the least the one on the 990, the 950 didn't have this unless you retrofitted it.
Old 03-22-2014, 03:49 PM   #15
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,888
Ours worked, not dead flat but not enough to start by itself.
Times are GMT -7.   It's 12:45 PM.
