Old 03-22-2014, 03:54 PM   #16
grant22 OP
grant22's Avatar
Oddometer: 478
^^^thats the scenario I'm looking at. Thx kiwi
grant22 is offline   Reply With Quote
Old 03-22-2014, 04:01 PM   #17
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,943
You're welcome.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-22-2014, 04:19 PM   #18
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 398
The fuse will fry.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 03-23-2014, 02:22 AM   #19
OldTriumphRider
Livin the Dream
OldTriumphRider's Avatar
Oddometer: 166
the Fuse
That's what happened when I tried to jump through the battery tender SAE..
I then removed the fuse by cutting it out and soldering the wires back together.
OldTriumphRider is online now   Reply With Quote
Old 03-23-2014, 04:30 AM   #20
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,943
Same but I cut the fuse out before we "needed" it, solid link for starting if needed, only once was enough to be worth while.
Old 03-23-2014, 06:18 AM   #21
Mikef5000
Oddometer: 2,030
you realize why that fuze is there right? A short on you unfused wire = fire! Game over! Wire can only handle a certain amount of power... Just up the fuse to the max for the wire. If the fuse still blows, it's a sign to stop what you're doing.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 03-23-2014, 08:17 AM   #22
car94
What's this Box for?
car94's Avatar
Oddometer: 3,816
I know it would be time consuming, but why not just take the battery out of the dead bike and take the one out of the bike that is running. Swap them and ride until the dead battery is charged back up. I know my ZX-14 and my XR 650 will continue to run when the battery is removed.
Ride Your Own Ride
car94 is offline   Reply With Quote
Old 03-23-2014, 11:36 AM   #23
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 432
If you need to jump start from another vehicle, please use jumper leads which are typically 6mm or 8mm diameter cable, crocodile clips on each end. As others have said, the 1.5 mm diameter battery charger tender wire is only for use with low current trickle chargers, definitely not for jump starting or charging from another battery. The tender lead and KTM charger is rated at only a few amps, you will blow something or cause a fire if you try starting with it plugged in. Jump start leads are designed for starter motor current of 50 to 100 amps.
RobZorba is offline   Reply With Quote
Old 03-23-2014, 11:42 AM   #24
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,943
Yes well aware, we have one purpose for that wire so a fuse is useless.
To start it with it down worked fine, with a flat battery yeap bad juju, so no fire, still have the bike, it started when it was down, not flat.
Old 03-23-2014, 03:44 PM   #25
NKL
Oddometer: 186
Can't see how it can fry anything, if mine doesn't have enough voltage it just throws the starter out and doesn't draw any current, when mine didn't start the other day I plugged my charger in to the SAE plug for less than 2 minutes and it was enough to start it so I am going to make up some leads to carry on the bike.
NKL is offline   Reply With Quote
Old 03-23-2014, 04:27 PM   #26
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Next post on Andy's ride report a story about Maya being burnt to the ground.
Just joking, as long you aren't trying to suck 200 amps down the cables they will be fine, they won't work for a full jump.
The fuze is there to prevent the bike from overloading a Battery Tender, so removing it for jump starting isn't an issue.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 03-23-2014, 05:09 PM   #27
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,943
Yes that is my take, not sure why a few are getting uptight about it, the OP said down a bit NOT flat as a turd.
Also, so the firemen among us can rest easy, now we have our new battery in place I removed the cable when I fitted the new battery however the SAE lead DID hook us out of the shit which I am happy and grateful for.
Old 03-23-2014, 05:12 PM   #28
grant22 OP
grant22's Avatar
Oddometer: 478
I'll let it slide ;)
Old 03-23-2014, 05:20 PM   #29
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,943
...that was lucky
Old 03-23-2014, 07:34 PM   #30
Wonway
KTM Fanboi #2
Oddometer: 428
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Times are GMT -7.   It's 07:42 PM.
