Old 03-24-2014, 10:25 AM   #16
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 911
Check the exhaust header graphite gaskets where they get together with the rear Y into the cans. I've seen those gaskets rusting and becoming nothing but a ring of wire that leaks everything.
more info here (similar setup)
Even the background noise of the distribution seems to be normal
690R
Gustavo.Ramos is online now   Reply With Quote
Old 03-24-2014, 10:48 AM   #17
zeropoint
Oddometer: 149
Agreed. As far as I can tell from the audio this sound reminds me of a time last year whilst travelling when I started to hear strange sounds that got progressively worse. Somewhere in the middle of Spain I stopped again to check it and tracked it to one of the graphite rings which was now blowing like Moby Dick breaking surface for air. The whole thing just dropped out in my hand. Managed to get a new one locally (but they only had one) and the other one went 1000km later.
2011 990 Adventure
zeropoint is offline   Reply With Quote
Old 03-25-2014, 07:21 AM   #18
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 719
Except the "clank" kills the bike, not him shutting it down. An exhaust leak wouldn't do that, would it?
effensteve is online now   Reply With Quote
Old 03-26-2014, 05:15 AM   #19
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,718
If it's not an exhaust leak, I would lean towards cam chains. At 37K miles, my front chain was stretched, and the front most plastic cam chain guide on the front cylinder was about 50% worn through. Cam chain noise was pretty loud. After a top end rebuild with new chains and guides, all noise was gone. Have you put in the newer cam chain tensioners that are longer? If you have chain stretch or guide wear, the longer tensioners might do the trick for awhile.
Orangecicle is online now   Reply With Quote
Old 03-26-2014, 08:07 AM   #20
gearheadE30
gearheadE30's Avatar
Oddometer: 879
No, it would not.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 03-26-2014, 08:16 AM   #21
Gustavo.Ramos
Oddometer: 911
Take the CCT bolts out and check for distance of CCT bolt to head, should be 6 ~ 11 mm
Can you make a vid of that clakning sound you hear when shutting the engine off?
690R
Old 03-26-2014, 08:28 AM   #22
KtmPedro220 OP
KtmPedro220's Avatar
Oddometer: 69
I'll try and catch it. The clank stops the bike.
KtmPedro220 is offline   Reply With Quote
Old 03-26-2014, 02:46 PM   #23
keith_irl
Oddometer: 82
Really think its a hole in your exhaust manifold at front of bike I had the very same problem. Listen to mine http://www.youtube.com/watch?v=IbE18...e_gdata_player
keith_irl is offline   Reply With Quote
Old 03-26-2014, 04:44 PM   #24
Gustavo.Ramos
Oddometer: 911
Agree but the OP mentions a clank that stops the engine
690R
Old 03-26-2014, 06:46 PM   #25
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 996
dodgy sprag clutch ?
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 03-27-2014, 06:56 AM   #26
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,330
I'd like to hear this too, but I'd bet it's the starter torque limiter clanking under a moment of slight back-spin when the engine is shut off. The engine is causing the clank, not the other way around.
Cam chain noise is not unusual, either. These are noisy, tough engines, folks. Unless there's oil coming of a brand new hole in the cases...ride the damn thing.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 03-27-2014, 07:38 AM   #27
KtmPedro220 OP
Oddometer: 69
Trying to catch the clank but it's quite hard to catch it. Like I say it's the clank that stops the engine. I have no control over it.
Old 03-27-2014, 08:52 AM   #28
Gustavo.Ramos
Oddometer: 911
How are the plugs? I seem to remember you complained about poor fuel mileage.
If you have carbs messed up, an overly rich/lean mixture can shut the engine off without you doing anything, and then torque limiter can make some funny noises when the engine stops...
690R
Old 03-27-2014, 01:29 PM   #29
keith_irl
Oddometer: 82
I did have the clank and it really sounds like a starter clutch and it sounds like a really bad thing in the engine. I really dont know what it was it only happened me a handful of times thankfully I got the new pipes and it solved the problem. Maybe its got something to do with not enough compression on the exhaust? I'm really not sure but the new pipes sorted it for me.
Old 03-28-2014, 08:24 AM   #30
KtmPedro220 OP
Oddometer: 69
Oooo! Maybe. Cheers.
Times are GMT -7.   It's 10:47 AM.
