Old 04-28-2014, 09:05 PM   #136
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
Post a picture if you have a minute
I want to be unique, just like everybody else.
WORN INPUT SPLINES CLUTCH HUB SPACER R1150XX
http://advrider.com/forums/showthread.php?t=964425
cele0001 is offline   Reply With Quote
Old 04-28-2014, 09:35 PM   #137
azccj
azccj's Avatar
Oddometer: 11
Originally Posted by cele0001 View Post
Clutch hub works but it requires greater level of knowledge to install ( and more time.).Crank spacer would be a pure bolt up kit. ( if I am not missing something) . Right now it is probably about 2 months away. I have to get the prototypes done and test them out. I know that the hub spacer is possible, I want to see if this "third option " is and at what cost.
I would think that the clutch hub spacer would be the easiest/cheapest by far solution to the problem. If bolts are used instead of rivets, wouldn't the hub spacer be an almost pure bolt up kit once the original rivets are out? I got a feeling that someone who is smart enough to split the bike in two and remove the transmission, should be able to remove the old rivets and bolt the clutch and spacer together.
And thank you for taking the time and doing what you've done.Please put me on the list for the next run of hub spacers.
azccj is offline   Reply With Quote
Old 04-28-2014, 09:41 PM   #138
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
BMW 1150GS Clutch Splines spacer kit
Here is the next waitilist. I need to rethink the order process since it is taking some effort to keep track of people and not piss anybody off.
Motoyoyo
TxBikerScum
motodutch
Flatbutt.
Ez-rider
Azccj
There are different people with different skills and different comfort levels regarding clutch disassembly. There is also time involved in the clutch modification process. And then you have a custom part which is not readily available. There's always a trade off. Clutch spacer is the cheapest solution but there is always time cost (which none of us includes), and convenience of not having to drill out rivets.
I will reinvest my "profits" from the clutch hub to see if I can design this new kit also.
It would involve removing flywheel, installing spacer, bolting it back up, installing different pushrod, and that is it. ( as long as the starter plays nice)
cele0001 screwed with this post 04-28-2014 at 09:50 PM
Old 04-28-2014, 11:26 PM   #139
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
Request for assistance
Hello everybody that contributed to the thread.
Since our little board is getting very long with lots of old info I would ask for your assistance in cleaning it up.
If you contributed to the thread and the post is no longer relevant please nuke it (this is mostly people saying they want the spacer, maybe not a good sales tactics, but still).
Lets see if we can trim it down to something that a noob could follow.
Thank you and I am eagerly awaiting reports from early adopters. Thank you Dennis and others that expressed satisfaction with the product so far.
Esmir
Old 04-29-2014, 11:04 AM   #140
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
One important piece of information for those that are planing to use bolts to assemble the clutch hub.
Boltheads should be on the engine side of the hub.
As you are positioning the clutch plate boltheads will contact the spring plate. While tightening clutch cover bolts the spring plate will "run away" from the clutch plate, as it bends (or straitens depending how you look at it) Just an FYI since I got worried about this during my initial install with bolts.
Old 04-30-2014, 09:11 PM   #141
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
I will place an order for 10 spacers tomorrow. This would be last run for a little while anyway. I have some other toys to fix. Just got 2005 Sprinter bus and it is taking up all of the room (space and attention). And I will be testing the "third option" soon.
So the spacers should be ready middle of the month for those that are interested.
Esmir
Old 05-01-2014, 12:10 AM   #142
moralem
Oddometer: 145
Is this fix only for the 1150s or will it work on early 1100s? I had a spline failure and found a replacement tranny and had a new clutch done about two months ago. Now I have to have the mechanic go back in because the clutch is slipping after only 2000 miles. Since I am having him go back in was looking at this fix to prevent a future and second spline failure. Thanks.
moralem is offline   Reply With Quote
Old 05-01-2014, 03:47 AM   #143
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
Only 1100 that this will fit is 6 speed 1100's
Old 05-01-2014, 07:15 AM   #144
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
Motoyoyo
TxBikerScum
motodutch
Flatbutt.
Ez-rider
Azccj
Clamrider.
Old 05-01-2014, 02:59 PM   #145
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,424
GB should print up a reflective badge with that pithy statement, and hand it out to every rider-enthusiast vendor here...
Or if not a badge, how about a bandage? It's a tough crowd...
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 05-06-2014, 12:09 AM   #146
wctan72
Oddometer: 9
Hi Esmir, pls put my name on your upcoming list. My nick is . Thanks!
wctan72 is offline   Reply With Quote
Old 05-06-2014, 08:53 AM   #147
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
Motoyoyo
TxBikerScum
motodutch
Flatbutt.
Ez-rider
Azccj
Clamrider.
wctan72
Just a quick reminder, that I am not planning on making any more spacers after this batch, so if you are waiting until the last moment it is getting close.
I am expecting the parts to be done in a couple of weeks.
Esmir
Old 05-12-2014, 10:00 AM   #148
MauserC96
Oddometer: 3
spacer
Hi Esmir. Can you please add me to list. My 04' R1100S will be opened up soon for service and I would like the kit and rivets. Thank you. Regards, Tom
BTW I found this link on the Pellican forum where I was an active follower / sometime posting member when my 00' (single plug head / ABS 49,000ish miles) and then replacement 04' (dual plug / power assist ABS 23,000ish miles... yea weak I know) R11S was still current. just to say I'm not totally from nowhere.. just here. Thanks
MauserC96 screwed with this post 05-12-2014 at 11:00 PM
MauserC96 is offline   Reply With Quote
Old 05-12-2014, 10:26 AM   #149
Jimmy
get in the van!
Jimmy's Avatar
Oddometer: 37
I've had the spacer for a while but finally got some time to install it. Here are a few pics of the removal and install of the spacer. Thought they may be helpful.
Center punched then drilled out the original rivets using 3 different drills. Started with a 1/8 to get things started. next was slightly smaller than the hole. The last one is oversized and takes the rivet head right off.
All the parts ready to assemble.
Obtained the correct rivet set and air hammer. Ready to go.
Used the anvil to set the rivet.
Ready to install.
Jimmy is offline   Reply With Quote
Old 05-12-2014, 04:57 PM   #150
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 358
That is a beautiful job. Any comments regarding parts?
Times are GMT -7.   It's 07:51 AM.
