Old 03-21-2014, 11:41 AM   #16
sweatmark
Oddometer: 51
Originally Posted by cele0001 View Post
Thank you...
I believe that the bike would have long happy life. Either way it is not ready yet.
If there is enough interest I will run 10 parts. Right now I am hovering at about $100 for the kit but nothing finalized yet.
Count me in for a kit.
Oregon USA
Now: 2004 R1150R Rockster, 2007 F800S
Then: R850R, R1100R, R1150R, R1200C, Buell, crotch rockets
sweatmark is offline   Reply With Quote
Old 03-21-2014, 03:27 PM   #17
Jim Moore
Jim Moore's Avatar
Oddometer: 13,951
That's nice work there, neighbor! I'm very interested. Just so I'm picturing this correctly. On the curent setup there is left over spline on the clutch hub after everything is assembled. Your spacer moves the splined part of the clutch hub to the rear by 6 mm, which allows the total splined area of the hub to be engaged. We haven't actually solved the underlying problem, we've just given the splines additional meat that they have to chew through. Perhaps pushing the (inevitable?) failure so far into the mileage future that it becomes a non-issue.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 03-22-2014, 03:38 AM   #18
DSTEVENS
Oddometer: 372
Originally Posted by Steptoe View Post
Actually, with the bike neutral and with everything warmed up, you can hear a slight "chatter" if it's badly worn.
But it's very similier to the noise that lots of BM's make anyway. But if yours never made any noise, or you can now hear a slightly different noise, then it could be a sign.
BUT, be careful, because it's very easy to get paraniod over this type of noise, especially if you've a long trip coming up.
0H great, BANG,CLUNK,RATTLE,POP,WHINE,WHIR,TICK, and now I need to listen for splinage may not be finage.. D.
DSTEVENS is offline   Reply With Quote
Old 03-22-2014, 06:29 PM   #19
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 425
I would say that you are correct, except for the statement that "we haven't solved the underlying problem". I would go with maybe on that one (just to be conservative). Everything else is correct. I would say the last sentence reflects my exact feelings on this subject.
I want to be unique, just like everybody else.
WORN INPUT SPLINES CLUTCH HUB SPACER R1150XX
http://advrider.com/forums/showthread.php?t=964425
cele0001 is offline   Reply With Quote
Old 03-22-2014, 09:57 PM   #20
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,164
I would hazard that amount of spline engagement is secondary because some of them fail at low mileage. I think my friend's 2004 has let go at about 30k.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 03-23-2014, 10:03 AM   #21
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 425
If anybody has an example of a hub where the splines do not engage fully other than bmw 6 speed transmission I would like to see it. As far as the misalignment theory I would like to say that perfect alignment does not exist. There is no 0.00000000000 match anywhere in the machine world. So, would it be possible to assume that tolerances for alignment were assumed for full spline engagement and due to lack of that engagement what should be " normal" misalignment becomes beginning of spline wear which is then positive feedback loop into destruction.
Old 03-24-2014, 09:23 AM   #22
sweatmark
Oddometer: 51
Agreed. My father-in-law worked 35 years as truck fleet mechanic, and saw a lot of clutch splines. When I described the R1150** clutch hub overhang to him and shared pics of various shredded transmission input shafts, he nodded grimly and confirmed that he'd never before seen splined mating clutch parts with such a flawed [my word] design.
The OE parts have/had some slop as new parts, according to local dealer service guys. Take that slop, multiply it by the hub overhang, apply whatever dynamic imbalance or parts misalignment might be present, and you get progressive pitting or spalling in the load zone defined by the wacky splined interface geometry. That's my theory.
So, tweaking the R1150 hub position to avoid most or all of the spline overhang seems like the smart move... Next winter I will do a spline inspection and install the tweaked clutch hub kit.
Btw, the old mechanic called BS on anything to do with spline lubrication, since many serviceable truck clutch hubs he worked on had little or no residual grease evident after long service periods.
Oregon USA
Old 03-24-2014, 10:27 AM   #23
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,271
Even with the extended hub, the input splines are still 4-6 mm short of passing through the clutch-web plane (holds the hub to the disc). Even with full engagement, there will still be an angular force on the hub if the crankshaft and input shaft are offset from one another.
I don't know if this is or isn't an issue but it seems worth discussion.
roger 04 rt is offline   Reply With Quote
Old 03-24-2014, 11:03 AM   #24
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,122
That has been discussed before and it was a real concern to some.
I don't have the thread handy, sorry.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 03-24-2014, 11:07 AM   #25
cele0001 OP
Instigator
cele0001's Avatar
Oddometer: 425
Quick update
Due to the greater positive response than originally anticipated I went ahead and placed and order for 10 hubs. There will be no prepayment. I am still working on the rivet solution. My original "proof of concept" was just 5mm thick spacer that I bolted in with M5 bolts with red locktite. I pulled it out after 500 miles and there was nothing to report. I have since removed the bolts and installed rivets using hammer and punch. I don't like the possibility of lose parts in the transmission housing.This is the part of the process that I want to get "normalized" to make sure it is repeatable. Those that expressed interest (or even those who could care less) and have scrap clutch plate to play with please send me a PM.
This is what is spinning inside my bike as we speak. I put about 300 miles and removed it and re-installed it over the weekend to check. Nothing to report.
Old 03-24-2014, 11:46 AM   #26
roger 04 rt
Oddometer: 2,271
I'll look for it. I'm interested in this point. Of course there isn't an option for a longer shaft
Old 03-24-2014, 11:52 AM   #27
Terry
Terry's Avatar
Oddometer: 1,301
Someone had a longer shaft produced at one point. But it was upwards of a grand if I remember right.
Terry
"The rights of every man are diminished when the rights of one man are threatened." John F. Kennedy, June 11, 1963
Terry is offline   Reply With Quote
Old 03-24-2014, 12:04 PM   #28
roger 04 rt
Oddometer: 2,271
Terry
Yes, it was GSAddict!
Old 03-24-2014, 12:06 PM   #29
Terry
Terry's Avatar
Oddometer: 1,301
Ah yes. I only had to go back a couple of pages in this thread to be reminded of that!
Terry
Old 03-24-2014, 01:05 PM   #30
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,493
That is the thing. Even if the shaft went all the way into a bushing on the crank it wouldn't solve this issue. It isn't like the shaft is flexing.
Times are GMT -7.   It's 10:00 AM.
