Old 03-25-2014, 12:29 PM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Leo Vince Spark Arrestor Install
Hi guys and gals. I have the Leo Vince LV One carbon fiber exhausts. I'm trying to install the spark arrestor inserts and having a bitch of a time. First off, getting the other inserts out is near impossible. I ended up removing the exhausts and using a broom handle to tap them out from the inside. That worked. However, now when I try to install the spark arrestor inserts I can't get the holes to line up where you put the screw in that holds the insert in. Any tips from other Leo Vince LV One owners out there?
Here's a pic of the cans I have:
Thanks.
Old 03-25-2014, 03:16 PM   #2
srad600
srad600's Avatar
Oddometer: 688
I've got the same pipes, and had trouble installing the SA's on mine as well. I was able to install one easily, but then could not get the second one in to save my life. I eventually swapped the SA's between the pipes and they went in fine.
I'm not sure, but it felt to me like each SA went into a particular pipe. You might give that a try first.
srad600 is offline   Reply With Quote
Old 03-25-2014, 05:27 PM   #3
Newbusa
Newbusa's Avatar
Oddometer: 624
I ran into the same problem with my Akro pipes, I found if I ran the bike for a while I could take the inserts out and re-install them pretty easy.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 03-25-2014, 05:47 PM   #4
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,422
Had same problem. Heat it up the silencer and it will fit better. My biggest issue was getting the bolt to line straight so I dindt screw up the threading.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 03-26-2014, 09:45 AM   #5
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Thanks for the replies guys. I'll try heating up the exhausts. We'll see if that does it.
Times are GMT -7.   It's 12:26 AM.
