Old 03-26-2014, 12:58 PM   #1
juames OP
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,490
Oil Jet Size?
Went to clean the clutch oil jet today, and found out it still has the original blocking plug in it! Order a new jet and push rode from CJ right away.
I was thinking of drilling out the blocking plug so that I could ride until the new one arrives, but the smallest drill bit I have is a 1/16.
Will that be too big?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 03-26-2014, 02:16 PM   #2
Black Hills
Oddometer: 1,240
The jet is a 30, which I think is .3mm ? I have one on order as well since I thought I could blow through it with a little shot from the air hose to clear it out. I heard two ricochets but can't find it anywhere.
Black Hills is offline   Reply With Quote
Old 03-26-2014, 02:47 PM   #3
Sumi
Sumi's Avatar
Oddometer: 1,799
You've already been riding with the blind jet for a while.. A couple more miles won't hurt:) This whole clutch jet thingy is way overrated anyway.
Old 03-26-2014, 04:05 PM   #4
juames OP
juames's Avatar
Oddometer: 2,490
CJ Designs to the recuse!
New jet ordered and shipped in less than half an hour!
Thanks Craig!
Old 03-26-2014, 05:34 PM   #5
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,388
I am sort of agreeing with you. Mine had the plug in it until around 29k miles when I started having a grabby clutch. First thing I did was change the oil jet,,,, no difference. What did solve the problem was swapping the last steel plate in the pack. Over 40k miles now and it's perfect.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 03-26-2014, 06:08 PM   #6
juames OP
juames's Avatar
Oddometer: 2,490
I don't really have a "grabby" clutch, but do have some clutch drag while sitting a lights when the bike is warm. Could the disc swap help with that?
Old 03-26-2014, 06:39 PM   #7
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,388
Possibly.... I had a very slight dragging clutch also but the biggest annoyance was the grabbiness when cold. Doesn't cost anything but about 1/2 hour of time to do the swap. Pull the outer cover, remove the pressure plate and pick at the clutch plates out until you come to the last steel plate. Swap that one with any other in the pack and put it all back together.
Old 03-26-2014, 07:31 PM   #8
juames OP
juames's Avatar
Oddometer: 2,490
Thanks Boats, I'll give it a try!
Times are GMT -7.   It's 06:57 PM.
