12-13-2012, 05:36 PM
#151 | |
Oddometer: 5,903
Thanks for that. I don't have alot of experience with the posi-lock connectors, souldering is always better.
Garage Residents: '72 Norton 750 Combat, '74 Honda CT70, '74 Norton 850 Interstate, '81 Laverda Jota '89 Honda RC30, '91 BMW R100GS '08 BMW R1200GS |
12-17-2012, 09:55 PM
#152 |
Oddometer: 5,903
Mildly disapointed. Havn't had a chance to look at the bike for a few days now, busy at work. Just had a quick 1/2 hr on it tonite, and noticed the kit is incomplete. The 12" black 16 guage wire used to connect the black portion of the now vacant black/blue plugin,,,,,,to, the male blade of the now vacant starter relay,,,,,is not in the kit. I rummaged through my tool box to see if I had some new 16 guage wire hanging around. Nothing. So after work tommorow, I'll stop by the auto parts place to get a chunk of this stuff. I'm going by the recomendations in this kit to use new wire only.
Everything is looking good. Regulator/recitifier bolted on, rotor/stator all torqued on, most wires routed. Still wondering what would be the best, most solid switched 12v source off of this bike? The instructions in this kit 'sort' of say for 1970-1984 BMW's, that the power off the coils is the best switched 12v source. My '91 GS coil looks absolutely nothing like the old school coils in the pics the kit supplied. There is no access to a power terminal on my coil. There is a big warning note in the instructions stating that this source MUST be a solid 12v or this will cause unwanted high voltage from the regulator. Anybody have any thoughts on another really good switched power source that does not require major surgery to the stock harness? Steve
12-18-2012, 05:38 AM
#153 | |
Zen Adventurer
Oddometer: 5,241
On a trip around the world.... details here: www.nohorizons.net |
12-18-2012, 07:15 AM
#154 |
Oddometer: 534
The running light in your tailight is a good one. Other than that, you'd have to search for one with a test light. Also make sure you have a good ground. I seem to remember that a weak ground will also cause high voltage to the battery. I ran a seperate wire from the mounting bolt on the R/R to my neg side of the battery.
1979 V-1000SP 1988 R100RS 1996 R1100RSL 1998 CR250 |
12-18-2012, 07:41 AM
#155 |
Anchor Clanker
Oddometer: 18
Enduralast wire connections.
I've had the enduralast system on my '89 R100GS for many years now. I got it right after it was first introduced. I used the coil power connection at first until one day I noticed my voltmeter was reading high at 16 volts. It had always been a steady 14.5 volts until then. I cleaned up the connection to the coil and decided to make a more reliable low resistance voltage sensing point. I added a automotive relay that is switched by the ignition switch and feeds full battery voltage through the relay's 30 amp rated contacts. This isolated regulator voltage sensing path insures that the enduralast system regulator sees the correct battery voltage and therefore maintains the bikes battery at the 14.5 Volt output throughout all speeds and loads.. This relay setup has lasted many years and is easily tested and has provided many miles of troublefree riding.
12-29-2012, 08:05 PM
#156 |
Oddometer: 5,903
Finally got the bike together. Fired right up, charging at esentially 800rpm. So, initial output readings of the system seem quite high. At 4000rpm, voltage to the battery is 16.25 volts. With heated grips on high, and high beam on, battery is getting 15.85 volts. This is way too much. It seems to me at this point, that the regulator/rectifier is not doing it's job. It is grounded direct line to the battery. I must admit that I'm not surprised, I've had 3 Denso unit failures on other bikes of mine, and Ducati 'regs', where this unit was sourced, has a notorious reputation for burning up batteries because of too much voltage.
Any thoughts? Improper wire connections surely would result in 0 voltage output, or a complete short, I think. Steve
12-29-2012, 10:00 PM
#157 |
ride dirty
Oddometer: 419
Couldn't be more pleased with my Enduralast kit. Of course I've only had it installed for a few months. I'll write back on this thread in a few years with a different tune if it craps out on me.
2013 BMW R1200 GSW | 1973 BMW r75/5 toaster | 2011 Husky TE310 "4 wheels move the body, 2 wheels move the soul" |
12-30-2012, 01:30 AM
#158 | |
Oddometer: 255
The post above your post tells about a more or less similar problem. In your case, perhaps the ground wire between the engine and the battery might be the problem (or another wire in the charging system with too uch resistance). The regulator has to see the correct battery voltage to enable proper regulating. |
12-30-2012, 11:56 AM
#159 | |
Zen Adventurer
Oddometer: 5,241
12-30-2012, 05:33 PM
#160 |
Oddometer: 5,903
Thanks for the heads up on a god ground set up guys. Today, I built a more sustantial ground wire from the reg/rect body to the neg side of the battery. I used 10 guage wire, really paid attention to a good solder at both ends. Fired it up and got the following results:
800rpm - 13.15volts 1500 rpm - 14.55volts 4000rpm - 14.75volts 4500rpm - 15.10volts Still too high for my comfort. But the reduced resistance wire had a decent effect. I was looking at those giant 4 guage car wires they had, but they're too big for the battery connection. I really don't want any more than 14 volts at ANY rpm. I honestly don't know the spec range of this particular regulator.
12-30-2012, 05:44 PM
#161 |
De Jo Momma
Oddometer: 8,705
Are you sure it's not the voltmeter? Without starting the bike and having been sitting for a few minutes, what is the battery voltage reading? 12.4-12.7 is generally considered normal for a strong battery. If your meter reads higher than that, it might just be error in your meter.
Low-buck meters from Harbor Freight, etc, list something like +/- 8.0% or more for voltage readings. That could easily be a volt or more of error in the actual meter. |
12-30-2012, 07:06 PM
#162 | |
Zen Adventurer
Oddometer: 5,241
12-30-2012, 07:35 PM
#163 | |
Oddometer: 5,903
Geez, you may have something there. I just checked the readings after the battery's been sitting for 3 hours, it reads 12.95volts. The meter I've not been using for any of this work shows the battery at 12.66volts. Looks like I'm shopping for a meter tomorrow. The battery is a sealed wet battery, 25amp, 2 yrs old Interstate.
12-30-2012, 07:38 PM
#164 |
Oddometer: 5,903
Are you talking about the black wire that goes to the switched power? I've got that spliced into the coil +, which is a solid green wire on '91 GS's. Seems solid. I'll double check it. Maybe I should go big guage wire on that one as well?
12-30-2012, 07:45 PM
#165 |
Zen Adventurer
Oddometer: 5,241
Yes. Just to test, clip it to the + on the battery directly. Make sure the plug attached to the wire is not the one it came with. Clip it off, strip the end and attach to battery plus. Remove all intermediate steps... just to test.
