Old 03-27-2014, 11:32 AM   #1
dirtbikebagger OP
dirtbikebagger's Avatar
Oddometer: 88
990 valve check without throttle cable adjustment?
Im reading up on the valve check procedure, and just wanted to double check...
Can you remove the throttle bodies without altering the throttle cable adjustment?
dirtbikebagger is offline   Reply With Quote
Old 03-27-2014, 11:45 AM   #2
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 471
Thumb
Yes, no problem.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo is offline   Reply With Quote
Old 03-27-2014, 12:40 PM   #3
dirtbikebagger OP
Oddometer: 88
Thanks, just had to make sure, now I'm having fun getting my 2010 spark plugs out =]
Old 03-27-2014, 12:46 PM   #4
dgjackson40
Oddometer: 247
Spark Plug
I completed a valve adjustment two weekends ago. I thought my Goldwing spark plug tool would work but it didn't. I had an old spark plug socket and took it to my bench grinder and just evenly ground off at bit around the entire socket. It works perfectly and is now in my bike tool pouch.
The trail is the thing, not the end of the trail. Travel too fast and you miss all you are traveling for. Louis l'Amour
2007 KTM 990 Adv; 2005 VStar 1100 Sold!; 2002 GL1800
dgjackson40 screwed with this post 03-27-2014 at 12:57 PM
dgjackson40 is offline   Reply With Quote
Old 03-27-2014, 12:58 PM   #5
dirtbikebagger OP
Oddometer: 88
The interwebs made me too nervous about that spark plug tool, turns out a regular ole 14mm deep well socket worked great to remove the LKAR8BI9.
Old 03-27-2014, 01:08 PM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,119
Really? What brand of socket was that? Was it free to turn or did it drag on the walls?
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is online now   Reply With Quote
Old 03-27-2014, 01:17 PM   #7
srad600
srad600's Avatar
Oddometer: 649
I used a regular deep socket on my 2011 as well, worked perfectly.
srad600 is offline   Reply With Quote
Old 03-27-2014, 01:31 PM   #8
dirtbikebagger OP
Oddometer: 88
Craftsman 14mm. fit very freely.
Finding these damn spark plugs to purchase is proving to be harder than I expected. Good thing its raining.
Times are GMT -7.   It's 08:42 AM.
