Old 03-27-2014, 07:44 PM   #16
Maoule OP
Maoule's Avatar
Oddometer: 426
Thanks for the good replys...is the mud build-up that actually kills the fender from the sides of the tire, or the top, or both?
Maoule is offline   Reply With Quote
Old 03-27-2014, 08:03 PM   #17
Jdeks
Departed
Oddometer: 970
All.
Jdeks is offline   Reply With Quote
Old 03-27-2014, 08:13 PM   #18
Clink
Beer break???
Oddometer: 26
http://slavensracing.com/shop/high-m...-for-ktm-1190/
This is what I'm going to get
KTM 1190 ADV-R
CRF250X
YZ450
Clink is offline   Reply With Quote
Old 03-27-2014, 10:50 PM   #19
desert sky
Location: Somewhere between snowmobiles and motorcycles
Oddometer: 44
It is not about mud build up destroying the front fender, it is about the build up of mud in the front fender causing the front wheel to expectantly stop spinning. And then you are on your face. Ride off road, go with the high dirt bike fender. It is a 3 minute job to change out the two fender set-ups. ds
desert sky screwed with this post 03-27-2014 at 11:35 PM
desert sky is offline   Reply With Quote
Old 03-27-2014, 10:54 PM   #20
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 1,933
Originally Posted by Clink View Post
What are you doing as far as protection for the fork sliders?
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
"Adventure is worthwhile in itself" -Amelia Earheart
scudrunner82 is online now   Reply With Quote
Old 03-28-2014, 01:38 AM   #21
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,883
Fork protectors.
+1
I am going to cut some adaptors to mount KTM 85 SX protectors on the 990Adv. When I am ready, I may have some for sale.
Cheers.
Old 03-28-2014, 06:37 AM   #22
Fundy Rider
Where 2?
Oddometer: 234
I have a 05.5 950 and raised my fender with some simple aluminum spacers where the fender is attached. I measured clearance on the fender to contact area on full compression and ended up using a .875" spacer on the rear and .750" for the front spacer. It just kisses on contact on full compression.
For the brake line I drilled a couple holes and moved the brake line forward with a cable tie. Running a Michelin starcross HP4 up front in a 90-100-21 which is a bout .375 taller and wider and it has given me enough clearance with this tire.
Sorry for no pics but bike is behind a workbench hiding behind my klr with my Toyota 22re head off and parts all over the garage as this winter won't go away.
I should add the reason I put more clearance on the rear is that it bows out the fender at the rear so you gain side clearance as well as the height. I messed around with a few ideas and have been happy with it as I like the look of the rally fender. Sorry about the multiple edits too early in the morning for me.
Fill your soul everyday
Fundy Rider screwed with this post 03-28-2014 at 06:58 AM
Fundy Rider is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
