Old 03-29-2014, 12:06 PM   #1
dirty_t OP
dirty_t's Avatar
Oddometer: 153
Question What front tire with Tourance EXP?
My 2012 GS12 has about 9200 miles on it, and at around 6500 miles I put on a new Tourance EXP rear. It's still looking very nice, but the front is getting pretty smooth. With a big trip coming up in a month, I want to make sure I've got the front sorted out with some new rubber, but I'm leaning toward trying something else.
Ride 90/10 road, lots of twisties here in NorCal, about half of that two-up. Will do a gravel fire road now and again. Don't mind the dirt, just not what I'm into these days.
I'm used to the front lasting through two rears - not gonna happen with these Tourances. So thinking of trying PR3's after reading a bunch of threads about Anakee3 (too noisy), and some others.
Wondering about following:
1. Is the PR3 the same as a PR3Trail?
2. If different, which one is recommended for above type of riding?
3. Most important of all - any thoughts on adding a PR3 front to the Tourance EXP rear until it's shot, and then going with PR3 all around?
dirty_t is offline   Reply With Quote
Old 03-30-2014, 11:26 AM   #2
dirty_t OP
dirty_t's Avatar
Oddometer: 153
OK. I get it. Maybe PR3+TouranceEXP = bad idea.
How about Tourance Next on front, and EXP on rear? (probably already a thread on that - will do a search).
Old 03-30-2014, 02:21 PM   #3
568V8
Ontario Vstrommer
568V8's Avatar
Oddometer: 199
regular Tourance
I found that the regular Tourance tires lasted more miles than the EXP; on my Vstropm DL1000.
568V8 is offline   Reply With Quote
Old 03-30-2014, 07:19 PM   #4
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,008
+1 Way more miles out of the std. Tourance.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 03-31-2014, 05:16 AM   #5
DSTEVENS
Oddometer: 371
My 13 GSA rear EXP lasted 3600 miles. I put regular Tourances on front and rear, and alls good. EXP stands for EXPires too fast. D.
DSTEVENS is offline   Reply With Quote
Old 04-01-2014, 08:54 AM   #6
dirty_t OP
dirty_t's Avatar
Oddometer: 153
* I emailed Metzler customer service (not Michelin as originally stated). Thanks GSAddict for catching the error.
dirty_t screwed with this post 04-08-2014 at 04:08 PM
Old 04-01-2014, 10:13 AM   #7
SFC E
SFC E's Avatar
Oddometer: 37
I am currently running a PR4 front and EXP rear on my Tenere. I have been riding this way for about 1500 miles without issue waiting for my second EXP rear to wear out. I will be picking up the PR4 trail for the rear in the next few days. This is the first time I didn't replace my tires as a set and regret it because I lost confidence in the EXP front about 3k after I replaced the rear.
SFC E is offline   Reply With Quote
Old 04-01-2014, 11:37 AM   #8
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,008
Originally Posted by dirty_t View Post
I emailed Michelin customer service and asked them about mixing Tourance EXP and Next tires. Here is what they said:
Mystery solved. Ordering a Next front tire today.
xxx
You mean you emailed Metzler
Old 04-08-2014, 04:07 PM   #9
dirty_t OP
dirty_t's Avatar
Oddometer: 153
You are correct. Thanks for catching it.
Old 04-08-2014, 05:05 PM   #10
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 1,134
Thats why I always replace at the same time.
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Old 04-08-2014, 05:07 PM   #11
SidewinderX
Hey, watch this!
Oddometer: 1,134
I went through a set of Tourance EXP's quickly as well. That was the worst set of tires that I have had in a very long time. They wandered, wore quickly, and was an overall confidence killer on my GSA.
Currently running PR4's and love them. Just a few hundred on them so far but very very good street tires.
Daniel
Times are GMT -7.   It's 09:31 AM.
