Old 10-12-2014, 11:03 AM   #1
kamanya OP
Andrew to most
kamanya's Avatar
Oddometer: 1,308
Rallye Suspension Setup?
I am a curious noob. There's not much advice out there that I've found. MX, Enduro and DS'ing have their biases.
Is there a consensus? How do you prefer to run yours? What's the difference between the bigger bikes and the current smaller 450's?
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 10-13-2014, 01:03 AM   #2
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 233
I run them pretty soft, because rallies seems to be always in places with a lot of rocks . But you still want as much bottom resistance as possible for those missed holes in the pistes.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 10-13-2014, 01:41 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,246
Sounds like progressive rate springs might be the way to go? Or at the very least two or three stage shim stacks.
Chuckracer is offline   Reply With Quote
Old 10-13-2014, 10:17 PM   #4
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,898
I tend to agree, a softer setup will be less fatiguing over multiple days. But you still need bottoming resistance.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 10-15-2014, 07:29 AM   #5
ROKIT_71
Gone Orange
Oddometer: 223
Yes soft suspension definitely. Also fining a happy set up between fully loaded with fuel and empty.
Most imprint ant thing for me is the fork to be set soft in its initial stroke. Rally is mostly rocks and when you are hitting them all day a nice soft initial stroke is so mush less fatiguing.
ROKIT_71 is offline   Reply With Quote
Old 10-15-2014, 08:12 AM   #6
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,898
ROKIT is right.
I ran the Stage 3 settings from Konflict Motorsports in the Baja Rally last month and it was great. Soaking up the small stuff, while still stiff enough for the whoops and jumps.
The KM3 setting is compliant for the first couple inches.
I've also found this setting works well on the 2 stroke in our local enduro series.
Log Riding 101
Times are GMT -7.   It's 12:13 AM.
