Old 04-13-2014, 11:21 AM   #16
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
My -78 RS
Installed battery charger quick connector.
Red flash means that the battery needs charging.
BrooklynS screwed with this post 04-14-2014 at 05:33 AM
BrooklynS is offline   Reply With Quote
Old 04-14-2014, 05:32 AM   #17
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
Filling up.
Old 04-22-2014, 01:22 AM   #18
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
Coffee break, as an eagle was flying low where we sat. :)
Old 04-23-2014, 02:19 AM   #19
Sunbeem
Enfant du Paradis.
Oddometer: 194
Very enjoyable story, looks like you've done a great job.
If you find the front brake less than perfect, a good mod is to mount a splitter under the tank, and a 13mm master cylinder on the handlebars. That's what stopped my
'78 RS from mating with a tractor.
Sunbeem.
Sunbeem is offline   Reply With Quote
Old 04-23-2014, 04:41 AM   #20
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
Originally Posted by DoktorT View Post
Note: you have the original front wheel which was recalled in the US. Any US dealer will replace that for no cost here. Just clean it and inspect very closely for cracks, and see if your local dealer will replace it there as well.
I think it's the replacement one already. See the ribs. I hope you've got a new tyre though!
boxerboy81 is offline   Reply With Quote
Old 04-23-2014, 04:57 AM   #21
FrankR80GS
Oddometer: 352
Laugh
Good work, nice results! Thanks for saving an early RS from being scrapped or even worse, ending up as a scrambler, bopper other hipster cafe cruiser.
FrankR80GS is offline   Reply With Quote
Old 04-23-2014, 11:17 AM   #22
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
My -78 RS
(Well... We're building a scrambler also, of a '81 R100 wreck that we caught up nearby. ;) but that was a real dog.)
Thanks for your comments, I do like the original way and '78 RS actually was a dream since I was eight years old (1978) and read the test in Motorrad. That's why I want the original brakes, it's not a new bike and has to be driven that way. Actually, when you have new brake parts and adjusted calipers, they are not too bad for its age. But you have to be strong in your right hand...
Today I greased up the splines in the bevel box, just to be sure. Also fitted the Krausers.
About the tires: New Michelins are fitted. :) (Old ones beside)
BrooklynS screwed with this post 04-23-2014 at 12:41 PM
Old 04-24-2014, 02:52 PM   #23
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
Quite nice sunset about nine o'clock this evening here about 100km from the Arctic circle.
Old 04-24-2014, 02:53 PM   #24
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
But this is Airhead stuff:
Old 05-03-2014, 12:52 AM   #25
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
About 120 km, of them about 40 km really bad road without Tarmac, or real track in the wild. Slippery now when the snow is melting but good balance training. Maybe I should have bought a GS instead?
Coffe break at a friend.
Old 05-04-2014, 11:34 AM   #26
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
Today some training for the season.
Old 06-04-2014, 01:46 PM   #27
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
Changed oil in the bevel box and drive shaft.
The oil looked like copper paste. Anyone seen that oil before?
Same sort of oil in both places.
Changed to GL-5 transmission oil.
Old 06-04-2014, 01:56 PM   #28
DK Dan
DK Dan's Avatar
Oddometer: 231
Some transmission oils are red when new so maybe it's just a normal color change. I would be more worried if it was cappuccino colored meaning that the oil would probably be contaminated with water.
Nice RS by the way
R100 G/S Paris Dakar ('87)
DK Dan is offline   Reply With Quote
Old 06-04-2014, 02:00 PM   #29
BrooklynS OP
BrooklynS's Avatar
Oddometer: 43
I have Redline transmission oil in my gearbox, but this is not even close to red... :)
But I also think this is better than water polluted oil. Weel, it would be nice to know if someone knew what kind of oil this is.
In the gearbox it was an oil coloured like smashed banana... Yellow, icecream like. Maybe Omega or something?
(Thanks, I also like my RS very much!)
Also updated my charging to the http://www.motorworks.co.uk/vlive/Th...F/ELA00045.pdf Works perfect! Now I can use my heated grips as much as I want... Ignition is also electronic: Piranha.
Old 06-04-2014, 02:14 PM   #30
bmwloco
bmwloco's Avatar
Oddometer: 1,508
Rode my '83 R100RS from the mountains of NC to very rural Alabama, exactly 247.3 miles.
Ran out of gas.
Oh well. At least I know how far it will go at 75-80 mph.
Not charging? Diode board? Check all your electrical connections; pull off and coat with dialectic grease and you'll be good.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Times are GMT -7.   It's 03:00 AM.
