Old 04-04-2014, 05:14 AM   #16
AdvRonski OP
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 695
Thanks, O-cicle.
You know, if the winters weren't so long here, all of my bikes would be a lot closer to stock.
8 more inches overnight! What's next?
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 04-04-2014, 06:16 AM   #17
Orangecicle
Orangecicle's Avatar
Oddometer: 2,572
Originally Posted by AdvRonski View Post
Thanks, O-cicle.
Man, thank goodness my garage isn't heated. Otherwise, I'd be bankrupt.
Orangecicle is offline   Reply With Quote
Old 04-04-2014, 06:44 AM   #18
sproot
Sturdy Adventurer
Oddometer: 220
Does it get hot? I've thought about doing that, but seem to remember hearing something about it being too hot close to the exhaust.
I was considering running a couple of leads up there from the stock position, because jumping (it or others) is a pita, but that looks a much nicer solution. I'll move the tyre pump that's in there now down to the battery box, although that probably means a flat first time out
sproot is offline   Reply With Quote
Old 04-04-2014, 07:46 AM   #19
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,834
They were wrong.
The bike handled sluggishly, resisted quick transitions, and pushed the front end badly into corners.
They learned that when the rider counter-steers the bars, and we feel the bike leaning over, what actually is happening is we are steering the wheels out from underneath the bike. The heavy fuel tank was resisting this process, and turned sluggishly. Under braking, without the weight of the fuel above the engine, not enough weight transferred to the front wheel, and it pushed wide through the corner.
Well, anyway, I'm having a blast with the way it makes the bike feel, and I would recommend this mod to anyone who pushes their bike hard.
When you look at the Honda you can visualize why the transitions felt heavy. When the front wheel is turned the lower part of the motorcycle moves out from under the upper part. The less massive the lower is the lighter it would feel. With the mass of the fuel tank low it would feel massive to steer.
I wonder what those expansion chambers felt like right under you face?
DELTATANGO is offline   Reply With Quote
Old 04-04-2014, 08:18 AM   #20
AdvRonski OP
Oddometer: 695
I haven't seen any heat related issues,but it's pretty cool around here right now.
I think going to the 2 into 1 exhaust helps a lot, since you eliminate the left side header pipe that runs right under the box.
Ronski
Old 04-04-2014, 08:21 AM   #21
AdvRonski OP
Oddometer: 695
No kidding!
Even though there was an insulated shell above the pipes, by the end of a race it must have been pretty toasty.
Ronski
Old 04-04-2014, 05:56 PM   #22
keener
Speed changes you.
keener's Avatar
Oddometer: 928
I thought it's a good thing that battery is so low. May be this is only true for off road riding?
04 ADV 950
keener is offline   Reply With Quote
Old 04-05-2014, 03:05 AM   #23
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
If that were the case all dirt bikes would have a battery mounted down there.
950A, 660RR, 640A, 250EXC-2t, RM125C, PE175C, TM250
Lc8grrr is offline   Reply With Quote
Old 04-05-2014, 06:07 AM   #24
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,132
Good for stability, bad for lifting the front wheel!
Verstuurd vanaf mijn LG-D802 met Tapatalk
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 04-05-2014, 07:28 AM   #25
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,275
The Super Enduro has the battery in that exact spot..... heat is not an issue.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 04-06-2014, 09:03 AM   #26
5 speed
Oddometer: 891
Thanks, O-cicle.
Dude so sorry to hear that. In Florida, I have upgrades to do but its the perfect weather right now so I just have to ride it!! Just coming out of the no humidity, cool mornings weather pattern. Now in the high 80s. Humidity and heat on its way in about two weeks. In the dead of summer July-Sept the garage is just too hot to work in. Anything rubber or plastic drys out and dry rots. Tires, tubes, Boot Soles delaminate (just had my soles reattached to my Combat Boots), its just a whole other dimension, however the riding season is quite long!
5 speed is offline   Reply With Quote
Old 04-06-2014, 11:18 AM   #27
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,228
I don't know whether the heat would be enough to damage a battery, but the tool bin definitely does get hot. I had been carrying a small multimeter in the bottom of mine, and it ended up looking like this:
I still carry one, but in the upper part of the bin, and it seems to be doing fine.
Maybe some insulation under the battery would be a good idea?
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 04-06-2014, 04:59 PM   #28
AdvRonski OP
Oddometer: 695
Don't feel too bad for us up here. It was 60 today, and the snow is off the paved and gravel roads.
I put on 250 miles today, about 70% off-pavement. Sweet.
Wow, that got pretty hot.
Do you have 2 mufflers or a 2-1 setup?
My battery sits about an inch off the bottom of the floor of the bin, so that should help. I won't know until it gets warm up here.
Ronski
Old 04-06-2014, 05:06 PM   #29
MortimerSickle
Semi-Adventurer
Oddometer: 12,228
Stock 2 can setup.
An inch clearance likely would make a considerable difference.
G.H.W.S. 1878-1962
Old 04-08-2014, 04:11 AM   #30
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Doesn't it come with insulation stock? Yours may have fallen.
I've had good results with Moss racing insulation. I put it on the inside of my tanks and a few other places. I even covered coolant the pipe that goes into the water pump. It passes an inch away from the front header. Great adhesive. Been there for three years.
04 ADV 950
Times are GMT -7.   It's 09:16 AM.
