Old 04-08-2014, 03:16 AM   #31
keener
Speed changes you.
keener's Avatar
Oddometer: 953
Hehe I found my old post while searching for a link to the insulation I mentioned above
http://www.advrider.com/forums/showthread.php?t=894536
04 ADV 950
keener is offline   Reply With Quote
Old 04-09-2014, 04:16 AM   #32
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
The stick on insulation they use on the right hand fuel tank (where the exhaust pipe passes near the tank) would probably be a good option, too. You can buy sheets of it on ebay quite cheaply.
It's a sort of thin foam with adhesive on one side and silver foil on the other side.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 04-12-2014, 03:43 PM   #33
keener
Speed changes you.
keener's Avatar
Oddometer: 953
Found some old parts in the garage today...the photo shows the stock heatshield under the tool box, under the seat.
04 ADV 950
Old 04-12-2014, 05:10 PM   #34
HarryEye
Oddometer: 36
battery weight
Sorry, I didn't read the whole thread, but I must say that this seems a bit unnecessary. I just bought a new EarthX battery (the 24) for my 990, and it basically weighs...nothing worth even considering.
Yeah, I read lots of pros and cons of these new batteries, and it seemed to me that they were worth it. Not cheap.
You went to a lot of trouble to move the battery from the stock position, but essentially eliminating the battery weight is what I did. When I recieved it, I seriously tought that they sent me a dummy case, because the battery weighs what the plastic case LOOKS like it would weigh, if it were empty. I mounted it up, and the bike fired right up like never before.
Oh, it's exactly the same size as the stock one, too.
HarryEye is offline   Reply With Quote
Old 04-14-2014, 04:07 AM   #35
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Of course the other advantage to moving the battery is that you're reducing the chance of water getting to the electrics - especially if you also move the solenoid and reg/rect. Whether that is important depends on where you ride, I suppose :)
Old 05-19-2014, 08:17 AM   #36
sproot
Sturdy Adventurer
Oddometer: 248
I just did this, including moving the solenoid to where the SAS gubbins used to sit, I only had to extend one wire (the one from the regulator/rectifier), all the other cables just fit.
I used some ebay heat insulation on the new battery box, I'm not expecting any problems but we'll see.
950 A (04)
1190 R (13)
sproot is offline   Reply With Quote
Old 05-20-2014, 05:10 PM   #37
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 784
Wonder ,, the original battery spot is against the bottom of the engine, new one under seat, wonder what temp wither spot gets to, I my just have to put a thermister in there and see..
I figured out a Odyssey fits in the tool bin.. But FILLS it up. on the other hand the CCA would be nice..
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Times are GMT -7.   It's 04:22 AM.
