Old 04-02-2014, 06:02 AM   #1
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,595
Does my Mufflers have Silencers???
My moto is too loud!!! These pipes were on the moto when I bought it. Can anyone tell me about the pipes, model, material, etc? More importantly, how can I tell if the silencers are in the mufflers, assuming it had any to begin with? My 2007 ADV had Lexx pipes, which I liked a lot. Not very loud, very little deceleration popping and most important and the reason I installed them, they ran much cooler than the stock pipes. These pipes make good power, plus I have great fuel economy, but they are too loud and have an excessive amount of deceleration popping. I assume the popping is due to insufficient back pressure. The PO said the moto was remapped for the pipes.
The pipes, as seen in the photo, does have spark arrestors installed.
Donnie - Retired & Riding - 2010 990ADV - 45,050 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 04-02-2014, 06:33 AM   #2
tunp
tunp's Avatar
Oddometer: 287
pull the spark arrestor, the little allen head, this will pull out the screen. if it is just the screen you can purchase the quiet core which will help lessen the noise level. Mufflers are from FMF so you need the FMF quite core
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 04-02-2014, 06:38 AM   #3
dwj - Donnie OP
Oddometer: 14,595
Thanks! What does a Quite Core look like. I had looked at the FMF website, but could not find one. How does it fit inside the pipe? Thanks again!
Old 04-02-2014, 06:46 AM   #4
jeffjones
"offroad shit"
jeffjones's Avatar
Oddometer: 158
like the other guy said: the allen head bolt you see inside the tip comes out and the screen type arrestor can be replaced with a Quiet Core.
contact FMF directly to make sure you get the correct part number as they have a couple different versions.
Blah
jeffjones is offline   Reply With Quote
Old 04-02-2014, 06:54 AM   #5
OrangeDevil37
OrangeDevil37's Avatar
Oddometer: 356
you could also check the packing in the silencer. after awhile the fiber glass burns out and it can make it get annoyingly loud. if you repack them with fresh pack it should quite it down a little as well.
2013 990 adventure baja
2009 250sx
2008 690 Duke
2006 250sx-f
OrangeDevil37 is offline   Reply With Quote
Old 04-02-2014, 06:59 AM   #6
dwj - Donnie OP
Oddometer: 14,595
If I am understanding y'all correctly, if it has a spark arrestor, which it does, it can't have a Quiet Core. Correct?
I bough the moto in late January with 6,540 miles and the pipes were already on it. It has 15,600 on it now, but sounds pretty much the same.
Old 04-02-2014, 07:02 AM   #7
dwj - Donnie OP
Oddometer: 14,595
Here is photos of the spark arrerstor.
Old 04-02-2014, 07:04 AM   #8
dwj - Donnie OP
Oddometer: 14,595
The Spark Arrestor is Model# S9000.
Old 04-02-2014, 11:58 AM   #9
dwj - Donnie OP
Oddometer: 14,595
I went to RPM KTM in Dallas and they have spent a ton of time identifying my silencers. They are stainless steel from KTM's Power parts catalog. David Cannella from RPM is in contact with FMF trying to determine which Quiet Core fits it.
If I read the description correctly, these silencers do not have packing "
This stainless steel silencers feature a great price/performance ratio. Due the use of INOX for the outer sleeve and all innerparts we could achieve a outstanding durability. With removable noise reduction inserts.
For 950/990 Adventure and 950/990 Supermoto, not for 990 SM-T!
Only for racing!
Do any of y'all have these pipes?
dwj - Donnie screwed with this post 04-02-2014 at 12:06 PM
Old 04-02-2014, 03:06 PM   #10
bomose
bomose's Avatar
Oddometer: 1,236
You can do this if the other doesn't work out. This came from this thread.
http://www.advrider.com/forums/showthread.php?t=324017
I have the Q4 FMFs and they were still louder than I wanted, so I put these reducers in.
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Old 04-02-2014, 04:01 PM   #11
dwj - Donnie OP
Oddometer: 14,595
I have some ordered that will be here in a few days. Hopefully, they will be quiet enough.
Times are GMT -7.   It's 10:31 PM.
