Old 04-02-2014, 08:20 PM   #1
4corners14 OP
4corners14's Avatar
Oddometer: 661
How do I get this bolt to come out?
any suggestions on how to break this axle adjustment bolt loose?
I tried to heat it up.....it's rounding off the nut and it won't turn either direction. SUGGESTIONS?
4corners14 is offline   Reply With Quote
Old 04-02-2014, 08:33 PM   #2
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,536
Can you get a 3/8 drive impact wrench on it?
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 04-02-2014, 08:36 PM   #3
wcohl
Oddometer: 347
Several ideas, but they are messy.
Does your swingarm have a drain hole? The drain hole should be ahead of the weld where the extruded arm is welded to the machined axle block. I'm not as familiar with the bigger KTM's, but the 2004 and older smaller KTM didn't have a drain hole. The hole should be no larger than 1/8". When drilled the hole in my 2003, I was surprised at the amount of water that came out.
If your bike has a drain hole, hang the swingarm axle block down and fill with penetrating oil. Let it soak for a while.
If that doesn't work, drill out the existing bolt and retap for an oversize bolt.
wcohl is offline   Reply With Quote
Old 04-02-2014, 08:36 PM   #4
4corners14 OP
4corners14's Avatar
Oddometer: 661
No.....
[....the nut is attached to the slide that holds the axle. I can't see anyway to take the slide off.
QUOTE=scudrunner82;23844004]Can you get a 3/8 drive impact wrench on it?[/QUOTE]
Old 04-02-2014, 08:56 PM   #5
CollinsB
CollinsB's Avatar
Oddometer: 990
I just dealt with this very problem a few days ago... Tried the torch, penetrating oil, etc. nothing worked and eventually had to drill it out. Starting with a small bit, and worked my way up. Took roughly 15 minutes to drill and re-tap. Not too difficult.
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 04-02-2014, 09:52 PM   #6
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 723
Try to do as little damage as possible.
1st: Be careful with a torch and aluminum.
2nd: Throughly wet the area with a 50/50 mixture of automatic transmission fluid and acetone.
3rd: Get two small vice grips and clamp them to the bolt so that one tightens and one loosens. Set the jaws so they touch each other side by side.
Now rock back and forth: loosen-tighten-loosen-tighten. Tiny movements at first. Keep the area soaked with the penitrent. The bolt will eventually start to move. Keep the swings small, you don't want to fatigue the bolt and break it; you want to finness it out.
Be patient, it will take some time. It's possible the thread damage won't require drilling out. If you can grip the bolt on both sides of the threaded hole, that will help.
Once it's out you'll be able to prepare the hole for a Helicoil insert.
Good luck.
HeatXfer screwed with this post 04-02-2014 at 10:03 PM
HeatXfer is offline   Reply With Quote
Old 04-02-2014, 10:00 PM   #7
4corners14 OP
4corners14's Avatar
Oddometer: 661
I figured it out....
Inside the axle housing slide (orange) there's a c-clip holding the bolt to the slide....once I got the c-clip off the slide, the slide pulled off the bolt and I could get a socket on the nut. It was very tight but I eventually got it to back out. I'll tap and die the set and use some anti-seize this time!
Old 04-02-2014, 10:05 PM   #8
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 723
Great!
Old 04-02-2014, 10:20 PM   #9
JohnnyWaffles
Oddometer: 245
Happy ending!
2013 KTM 990 Adventure Baja Edition
Originally Posted by Beefeater Steve
The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
JohnnyWaffles is offline   Reply With Quote
Times are GMT -7.   It's 06:11 PM.
