Old 04-05-2014, 05:51 AM   #16
MassiveLee OP
It's a small world
Oddometer: 924
Originally Posted by billdonna View Post
Somebody correct me here if I'm wrong.
The wire to the solenoid terminal is hot 100% of the time. You disconnect a live wire to insulate it, because it is too much work to disconnect the negative terminal at the battery?
On the 1150GS, the battery is under the fuel tank. Fuel tank holds 30 litre of fuel or roughly 55lbs. Puttig a piece of tape on the wire near the starter is easier.
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is offline   Reply With Quote
Old 04-05-2014, 06:25 AM   #17
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 1,652
Appreciate the photos. Had the dreaded starter squeal so last winter i did a slight clean without the total disassembly. Solved the problem but your job looks like a better way of doing things.
R1150 GSA, KLR650, K75s, RD350, PS250 (Big Ruckus), R65, 990 Spyder
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 04-05-2014, 10:34 AM   #18
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,738
If you should happen to touch ground, you will quickly wish you had taken more time. The Arabs have a wonderful expression for this type of action....
"It is like licking honey from the edge of a razor"
You're not wrong and that wire to the solenoid is capable of carrying lots of current...enough to weld with.
But, in defense of Lee, he seems to understand the danger and took precautions and no battery or motorcycle was harmed in the making of the post.
But, Bill, I agree with you....we would have disconnected the negative (-) at the battery.
Now, about that oil...does anybody change viscosity from winter to summer?
def is offline   Reply With Quote
Old 04-05-2014, 05:35 PM   #19
cele0001
Instigator
cele0001's Avatar
Oddometer: 356
First I would like to say that I also disconnect the wire at the starter, but saying this is easier after mentioning that there is 55lbs of flammable liquid right above possible source of (big) sparks will not bode well for the safety crowd.
I want to be unique, just like everybody else.
WORN INPUT SPLINES CLUTCH HUB SPACER R1150XX
http://advrider.com/forums/showthread.php?t=964425
cele0001 is offline   Reply With Quote
Old 04-05-2014, 06:10 PM   #20
MassiveLee OP
It's a small world
Oddometer: 924
It is easier. It is safe. And it is no risk. People who doubt their mechanical abilities should keep away from wrenching ;-)
Old 04-07-2014, 04:59 AM   #21
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,024
I've worked on live electrical circuits standing on an iso mat, wearing rubber electrical gloves with leather outers and a flash guard. I fully understand how to work live and the hazards of not.
Nothing to do with doubting ones abilities, it's all about understanding the risk of accidental grounding. You say there is no risk, I say there is. Good luck in the future mon ami!!
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 04-07-2014, 06:27 AM   #22
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,277
For 70$ buy a new one. Had one on my bike for 65k miles with no problems.
http://www.ebay.com/itm/Starter-BMW-...a4ea96&vxp=mtr
Tbone is offline   Reply With Quote
Old 04-07-2014, 08:17 AM   #23
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,796
I too have worked on live equipment with the right safety gear.
I would say in this case it is a calculated risk.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 04-07-2014, 08:18 AM   #24
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,796
China quality (?) with no replacement parts. Hit and miss.
Old 04-07-2014, 07:52 PM   #25
def
def's Avatar
Oddometer: 9,738
Years ago, dad and I rewired the house without disconnecting the 120VAC 'cause mom wanted to watch TV. We pulled wire through rigid conduit and made connections on live circuits. I got nipped once, dad never got so much as a tingle. Of course, his profession was electrical engineer and he designed power plants for a living so he did know what he was doing.
Old 04-07-2014, 07:57 PM   #26
ragtoplvr
Oddometer: 6,055
The spinning without engaging is usually the failure of the one way roller clutch in the starter drive.
You can buy them
Rod
ragtoplvr is offline   Reply With Quote
Old 04-07-2014, 08:04 PM   #27
def
def's Avatar
Oddometer: 9,738
Few boxer owners need new starters.
Few boxer owners remove and rebuild their own OE starters.
Few OE starters are damaged beyond repair.
Most BMW boxer OE starters can be repaired to factory new condition, maybe even better.
Parts for the OE starter are available.
Replacing a repairable starter is a waste of money.
I've said enough.
Old 04-08-2014, 11:08 AM   #28
cele0001
Instigator
cele0001's Avatar
Oddometer: 356
You can buy them
Rod
This I can understand.
Old 04-08-2014, 11:31 AM   #29
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,277
I've said enough.
Ahh..Def, price what it costs to rebuild that starter using OEM parts and get back with me. Those that want to enjoy the mechanical satisfaction of repairing a starter, enjoy. I ride my bike everyday and the ability to buy a cheap replacement that bolted right in and continues to work years later makes sense for me.
Old 04-08-2014, 11:43 AM   #30
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,196
I greased mine, it was good, then it stuck again, greased it again......... eventually then I CLEANED it in detail, light lube never given issues since, over lubing with sticky grease is a bad idea
Welshman is offline   Reply With Quote
Times are GMT -7.   It's 12:16 PM.
