Old 04-08-2014, 12:01 PM   #31
MassiveLee OP
It's a small world
MassiveLee's Avatar
Oddometer: 1,063
Originally Posted by Tbone View Post
Ahh..Def, price what it costs to rebuild that starter using OEM parts and get back with me. Those that want to enjoy the mechanical satisfaction of repairing a starter, enjoy. I ride my bike everyday and the ability to buy a cheap replacement that bolted right in and continues to work years later makes sense for me.
Once you deduct the removal and refitting time (which you would spend with a new starter anway), the process of taking a starter apart, degreasing and relubing it is about 15 to 20 minutes. And you saved $200.00 by doing some basic maintenance...
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is offline   Reply With Quote
Old 04-08-2014, 12:11 PM   #32
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,085
Thats good to know that they can be bought so cheaply, and that you have gotten great service life out of it.
But from another perspective, I ride mine daily too, and sometimes I ride it to places that do not stock starters, cheap , expensive or otherwise, so I am glad to know what it takes to open the starter, clean it and make it work.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 04-08-2014, 07:18 PM   #33
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,009
A rebuild on the OE starter is difficult to judge unless we know the failure.
Tbone, I fully understand your situation and applaud your decision to replace rather than rebuild.
Finally, a carefully cleaned and repaired OE starter may be more reliable than the original.
def is offline   Reply With Quote
Old 04-08-2014, 07:25 PM   #34
MassiveLee OP
It's a small world
MassiveLee's Avatar
Oddometer: 1,063
Ah, ah, ah. Did I mention that this thread is about fixing and maintaining a starter? It will probably interest a few people who think it is difficult and who like doing stuff themselve. And if my starter fails 3 days away from home, I'll be glad I now know how to fix it in a rest area... ;-)
Old 04-08-2014, 08:48 PM   #35
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,892
price what it costs to rebuild that starter using OEM parts and get back with me. .
Actually Euromotoelectrics carries a lot of Valeo (OEM) parts reasonably priced.
AMHIK
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 04-08-2014, 09:12 PM   #36
mouthfulloflake
Not afraid
Oddometer: 17,085
Yep
magnets broke on mine, I think from hitting a huge culvert on a dirt road, or from my buddy beating on it, after it killed the battery. I will never know
new housing was about $40, been good since.
http://www.advrider.com/forums/showthread.php?t=466575
Old 04-09-2014, 05:37 AM   #37
kbroderick
Oddometer: 1,048
So speaking of maintaining the OEM starter, what's the recommended lube to use after I take it apart and remove the grime?
kbroderick is offline   Reply With Quote
Old 04-09-2014, 05:48 AM   #38
MassiveLee OP
It's a small world
MassiveLee's Avatar
Oddometer: 1,063
I will let other peoples chime in from their own experience. I elected to use a engine/tranny oil over grease. Grease will work in warmer areas but might be too thick in freezing temps... I don't hold the truth, so everyone's free to experiment and share.
Old 04-09-2014, 07:39 AM   #39
mouthfulloflake
Not afraid
Oddometer: 17,085
I used a very small amount of synthetic disc brake grease, very goey and high temp capable stuff.
I would imagine anything thicker than 3n1 oil would be fine though, as long as its clean.
Old 04-09-2014, 04:32 PM   #40
cantupshift
Oddometer: 91
Originally Posted by ragtoplvr View Post
The spinning without engaging is usually the failure of the one way roller clutch in the starter drive.
You can buy them
Rod
So looking at Anton's page it would be #3 ?
http://www.largiader.com/tech/valeo/
I don't want to go tearing into my starter just yet, but replacing this piece would do the trick?
http://www.euromotoelectrics.com/VAL...a-oildrive.htm
cantupshift is offline   Reply With Quote
Old 04-09-2014, 05:04 PM   #41
MassiveLee OP
It's a small world
MassiveLee's Avatar
Oddometer: 1,063
In my case it was a simple case of cleaning the old gunk and properly lubing the moving parts. Cost was 0 except for a few squirts of WD40 to remove grease, and some tranny oil (1/4 tea spoon).
Old 04-09-2014, 09:18 PM   #42
def
def's Avatar
Oddometer: 10,009
Correct. You might try soaking that piece in solvent to free it up. It is likely that clutch dust has fouled it.
Old 04-10-2014, 04:57 AM   #43
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,042
Next time try spray on graphite lube. Goes on wet but dries to a thin film. Doesn't attract dust and is not affected by the cold. Used to use it after stripping oil from rifles and lube them with graphite spray before use in the artic to prevent freeze up..
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 07-22-2014, 02:57 PM   #44
tinkerz
Sloroad Rambler
Oddometer: 11
cracked magnets in Valeo starter
Just pulled my starter to clean and lube. I found one magnet with a long crack running the length of it and one with a significant piece of one end missing. what can be done from here? Can new magnets be installed or do I need to buy new?
tinkerz is offline   Reply With Quote
Old 07-22-2014, 02:59 PM   #45
mouthfulloflake
Not afraid
Oddometer: 17,085
You need this if you have broken magnets
http://www.euromotoelectrics.com/pro...6ra-magccw.htm
Times are GMT -7.   It's 09:11 AM.
