Old 04-06-2014, 06:01 AM   #1
luca9277 OP
luca9277's Avatar
Oddometer: 250
R1150GS passenger handles
My previous 1200GS had some nice handles for the pillion, my current 1150GS came with nothing as the bar at the back had to be taken off to fit the top box.
My girlfriend reminds me this design shortfall every time we ride. At times she does so repeatedly over the shortest amount of time.
I do perform at my best under pressure so when she pointed out again "I've got nothing to hold on to on this thing" I had a strike of genius and thought to myself "Let's Google it!"
30 min later I bought a set of used bag mounts for the R1150R, apparently they need just a minor modification to be installed on the GS. Google said they works. If that on the internet it must be true!
Now I just have to wait for them to come all the way from the US & A.
luca9277 is offline   Reply With Quote
Old 04-08-2014, 08:47 AM   #2
abbocath
Oddometer: 8
Hi luca9927, i have the same problem on my bike and with my wife when we ride.
Can you tell me what kind of modifications your new supports need to be install?
If it was easy i will buy ones too!
Good curves!
abbocath is offline   Reply With Quote
Old 04-08-2014, 09:11 AM   #3
luca9277 OP
luca9277's Avatar
Oddometer: 250
I'll let you know as soon as they get here and I can put them on.
I saw it done on the Italian BMW forun and he said he just had to do a bit of filing of one of the connection points on the handles, hopefully it's easy enough! I'll keep you posted..
Old 04-08-2014, 11:01 AM   #4
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
are they compatible with every pannier system or is there some interference with some mounting points?
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 04-08-2014, 04:59 PM   #5
luca9277 OP
luca9277's Avatar
Oddometer: 250
from what I could read the bags for the 1150GS and the 1150R are the very same so mounting the bags on it wont be (I hope) an issue), they should be an easy fit on to the bike frame, I will take some pictures when I put them on!
Old 05-04-2014, 02:45 AM   #6
luca9277 OP
luca9277's Avatar
Oddometer: 250
I have finally received the handles and put them together, they fit but it takes a bit of work.
The rear bit of the handle is much larger where it meets the bike's frame so I had to chop it off a bit to make it fit.
At the front I had to put a spacer to be able to fit the seat back on.
M6 and M8 bolts holding the standard mounting brackets are too short to mount the brackets for the R1150R so I had to get longer ones.
I also had to trim a bit the lover side of the right mounting frame as I couldn't quite lock the bag, strangely the left hand side bag fit right away.
Overall however my pillion is now a happy one so that was worth the money and the time spent fitting it!
Old 05-04-2014, 11:28 AM   #7
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 947
Very nice and despite the ittle shaving and shiming, it is basically a straight drop-in. And it is factory. Thanks for sharing.
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is online now   Reply With Quote
Times are GMT -7.   It's 07:15 AM.
