Old 04-06-2014, 07:10 PM   #16
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,435
Originally Posted by bemiiten View Post
The cable pulleys are made of steel on the 1150.
That was a good design, I've only had to clear crud out of them once or twice.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 04-06-2014, 07:16 PM   #17
kbroderick
Oddometer: 1,041
They do fall off the shaft eventually, though, with potentially unpleasant results. Mine failed while riding a gravel road on the way back from a week-long vacation, resulting in the bike acting as if I had opened throttle to 100% (at least on that cylinder). I didn't manage to get the bike running on the other cylinder (or to get the pulley reattached, even temporarily) and had to resort to towing the bike.
With that said, there's somebody in Vendors who does 1150 throttle-body rebuild kits, even though the TBs aren't designed to be serviceable. Maybe he might be able to help?
kbroderick is offline   Reply With Quote
Old 04-06-2014, 07:44 PM   #18
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,621
Wow, I have never seen something like this before.
Curious, is that piece made of metal or plastic? I can't tell from the picture. To me it looks like plastic.
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 04-06-2014, 09:10 PM   #19
BKFoster OP
Oddometer: 168
It is plastic.
BKFoster is offline   Reply With Quote
Old 04-06-2014, 11:36 PM   #20
Beecher Snipes
Fool
Beecher Snipes's Avatar
Oddometer: 348
Check with Bing Carburetors, I bet they can help you. They do throttle body rebuilds and parts.
http://bingcarburetor.com/bmw/bmw.html
Beecher Snipes is offline   Reply With Quote
Old 04-07-2014, 02:24 AM   #21
diabolik37
Push Dumb C***
diabolik37's Avatar
Oddometer: 921
Originally Posted by BKFoster View Post
I didn't see him actually break them but it was fine earlier in the day when I rode it. They are inboard of the TBs so he couldn't have kicked them. I have 65,000 miles on the bike and have never had an issue with them before.
Yeah, I think he broke them. I won't mention to his dad because his dad didn't want him to sit on the bike but I said it was okay. I might tell the boy about the perils of forcing anything mechanical but I'm not going to make a big deal of it. I learned a lesson.
While I symphathise with your trouble, I think you really should said something to the 13 Years old kid. I think what he did it is a total lack of respect. You allowed him to sit on your bike. No one told him to play with it. You can help him learn the difference between the two...(with some form of punishment)...
I would recommend a fatal beating... But you may be inclined for a different punishment...
STOP the Planet! I want to get off!
diabolik37 is offline   Reply With Quote
Old 04-07-2014, 05:24 AM   #22
L21
Oddometer: 169
You should thank the kid, it was most likely on its way out already and he saved you a long walk home. I think its unlikely the kid twisting the throttle to its stops would brake it with out some sort of hairline crack or defect in the plastic. But that's just my opinion.
L21 is offline   Reply With Quote
Old 04-07-2014, 05:34 AM   #23
trout'r
Oddometer: 147
repair option
could try some plast-aid. saw a write-up in recent mcn. i immediately ordered some for a broken plastic part. check out their website for info.
trout'r
trout'r is offline   Reply With Quote
Old 04-07-2014, 05:37 AM   #24
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,025
It is plastic.
All is not lost. Here's my solution.
1. Clean all crud off plastic and steel arm
2. Epoxy the plastic back onto the steel as best you can.
3. Get a stainless steel washer approximately the outer diameter of the black plastic. Drill eight 1/16" diameter holes in the washer and epoxy it onto the face of the plastic.
4. Gently drill thru the eight holes in the washer thru the plastic, steel arm and plastic on the backside and epoxy 1/16" dia pins in the holes.
Not the most elegant solution, but the pins will hold the torque to the steel lever, not the broken plastic.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 04-07-2014, 06:32 AM   #25
BKFoster OP
Oddometer: 168
Yeah I have been thinking the same. I just don't see how he could put so much force into the throttle to break both of these so cleanly.
I haven't removed the second TB yet but I see this crack in the plastic and I wonder if they were on the way out anyway.
If these had been cracked for some time wouldn't there be dirt /grime in the cracks?
Old 04-07-2014, 06:36 AM   #26
WindSailor
WindSailor's Avatar
Oddometer: 648
Yep...
Pure lurker here - but this thread has my attention.
To find something this vulnerable now - is simply priceless. I'd rather find out this way rather than walking out 20+ miles or more. Trust me that would be a short walk.
BillDonna - like your solution, going to think about that one.
Now to look at my bike... And check things...
Sent from my Samsung Note 3
WindSailor is offline   Reply With Quote
Old 04-07-2014, 06:41 AM   #27
BKFoster OP
Oddometer: 168
I don't know. . . .seems pretty elegant in a Rube Goldberg kinda way. I am sure my lack of machining skill would have me drilling completely through the TB though.
Old 04-07-2014, 06:50 AM   #28
BKFoster OP
Oddometer: 168
Originally Posted by WindSailor View Post
Yep...
I doubt this is worthy of adding a new worry bead. I haven't heard or seen of this happening to anyone else. I seem to be a pioneer in finding new ways to jack things up.
I also don't see how you would be able to examine these plastic parts without removing the TBs. They are pretty well hidden.
Old 04-07-2014, 06:54 AM   #29
Bikerboy108
Pat from Jersey
Oddometer: 1,087
I would do this first
Pat from Jersey
Bikerboy108 is online now   Reply With Quote
Old 04-07-2014, 08:46 AM   #30
BKFoster OP
Oddometer: 168
I just got off the phone with Bing in KS. They don't know anything about the Bing 77 / 47 /101 & 102 throttle bodies. He said they only have parts for the 75 series and back. My parts are too new. He said he would have to call the Fatherland to see what would be an appropriate parts list. I never even got to tell him what I needed.
I thanked him for his time.
Times are GMT -7.   It's 09:33 PM.
