Old 04-08-2014, 01:11 PM   #1
drjason OP
awesome
drjason's Avatar
Oddometer: 6
Lighter oilhead wristpins in airhead engine (R100GS)
NOTE: I just copied this from "The Garage" because I think it is more relevant in this forum. I googled this and searched ADVrider and IBMWR and I couldn't find anyone having discussed this yet, but it seems like it is worth considering:
Success: Soaking piston in carb cleaner removes carbon very well.
Failure: Soaking wrist pin (gudgeon pin) in carb cleaner removes chrome very well.
Solution: Call re-psycle for a good used wrist pin. 11 25 1 335 474 GUDGEON PIN - 22mmOD X 13mmID X 74.31mmL
What arrived happened to be what I figure is an oilhead wrist pin. 11 25 1 341 365 GUDGEON PIN - 22mmOD x 17.5mmID x 74.31mmL.
It looks like it would fit just perfectly. The original wrist pin is 147grams, the oilhead wristpin is 83grams. Weight savings of 64g of reciprocating mass per piston.
Now I need to decide whether to send this back and order a proper airhead wrist pin, or keep it and ask for another oilhead wrist pin for the other side.
Question#1: Is there a heat/stress reason that the oilhead wrist pin shouldn't be used in an airhead?
Question #2: Why hasn't this been discussed before (or is my Google-Fu just not up to snuff)?
drjason is offline   Reply With Quote
Old 04-08-2014, 05:52 PM   #2
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
Just a guess but, changing the reciprocating weight in your engine may upset the dynamic balance of the engine. Also, a weight change at the pin bosses may also upset the rocking moment somewhat.
I would consult with an engine balancing service before putting your wrist pins on a diet.
def is offline   Reply With Quote
Old 04-09-2014, 05:53 AM   #3
Marki_GSA
Oddometer: 577
I am with def on this one.
In a world where engines are balanced to a gram or less this is a huge reduction in weight. Great idea if you replaced both and got it all balanced. Bad idea if you just replace one and do nothing about the balance.
Marki_GSA is offline   Reply With Quote
Old 04-09-2014, 05:54 AM   #4
Marki_GSA
Oddometer: 577
Oh and you might find your pistons are much heavier than an oil heads so the lighter/thinner walled pin might not hold up to the task.
Old 04-09-2014, 01:37 PM   #5
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 1,200
Weight the 1000GS pistons. If they are the same weight or lighter than an 1150GS piston, then go for it. On both sides. ;-)
In terms of balancing. The crankshaft is balanced on itself. It doesn't take in account the rods and pistons. If you fit a lighter pin, that is less weight for the connecting rods to keep moving back and forth. The lighter pin is most likley mandated to reduce weight because of the longer stroke on the 1150GS.
1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F
2001 BMW K1200RS aka Good Girl -- Current
2006 BMW R1150GSA aka Kim Kardashian -- Current
1988 Honda Africa Twin aka Queen of Sheeba -- Current
MassiveLee is online now   Reply With Quote
Old 04-09-2014, 02:38 PM   #6
Marki_GSA
Oddometer: 577
That's is not correct. The lumps sticking out from the opposite side of the big end on a crankshaft is the counter balance. The crank very definitely is balanced to the rod and piston, even on a boxer.
http://www.motoren-israel.com/produc...alancing.html& just the first link that came up.
Old 04-09-2014, 03:26 PM   #7
MassiveLee
It's a small world
MassiveLee's Avatar
Oddometer: 1,200
For having built several BMW 4-pot race engines, I will disagree on the wording, but will agree that when the big ends of the connecting rods are added to the equation, it must remain balanced.
You want to balance the crankshaft by itself, and lighten it if you want. That's part one. Part two requires that all connecting rods weight the same as a unit (I used to do it to the tenth of gram), and that all big ends also weight the same as well as small ends.
Old 01-29-2015, 03:29 PM   #8
BMurr
Oddometer: 83
That makes a lot of sense, but then what happens when you install those siebenrock upgrade kits with lighter pistons. Could it be that the boxer design balances itself to some extent such that a drop in weight such as that with the siebenrock kits will go unnoticed? Confused
BMurr is offline   Reply With Quote
Old 01-30-2015, 02:52 AM   #9
def
def's Avatar
Oddometer: 10,359
I'm still struggling with the chrome being removed...what chrome?
The woods is closing in on me...I need a D6.
Old 01-30-2015, 03:09 AM   #10
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
Naw...Lee has it right. The counterbalance is for the crank imbalance only. As long as the left and right rod/piston ass'y mass are identical, they have no effect on balance.
Read your link again. Counterbalance is for a rotating mass like the crank, pistons are an oscillating mass, 180 degree opposed = cancelling.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 01-30-2015, 03:41 AM   #11
Dan Căta
Dan Căta's Avatar
Oddometer: 1,676
So.. did anyone try this yet? Is it worth the trouble?
Dan.
Dan Căta is offline   Reply With Quote
Old 01-30-2015, 05:40 AM   #12
GrouchyGeezer
GrouchyGeezer's Avatar
Oddometer: 860
I'm with def on this one!
Also, "carb cleaner removes chrome", huh ...what? What in heaven's name are you using for carb cleaner?
GrouchyGeezer is online now   Reply With Quote
Old 01-30-2015, 08:58 AM   #13
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,026
Lightweight piston pins for Airheads has been around for decades.
Never heard of anyone using Oilhead pins, however.
This is mostly applicable to the 1000 Airheads, as the smaller displacement motors exhibit hardly any vibration. I never minded the feel of the stock 1000 anyway.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 01-31-2015, 07:55 PM   #14
def
def's Avatar
Oddometer: 10,359
Balancing a piston engine is a science that few understand well. There are several factors in play as the engine rotates as well as rocking moments. Installing a rotating or reciprocating item that is not sympathetic with the engine balance will ruin your day.
Old 02-02-2015, 10:26 AM   #15
def
def's Avatar
Oddometer: 10,359
Read this before you go changing rotating or reciprocating weight in your engine;
http://www.tonyfoale.com/Articles/En...ineBalance.pdf
Times are GMT -7.   It's 05:35 PM.
