Old 04-20-2014, 07:59 AM   #1
caponerd OP
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
They're out. Finally.
Any accusations that I'm a welder will be denied vehemently.
I'd been playing around with some 18ga. sheet metal, then decided I could handle putting a bead around the outer steering head races in my R100 frame.
Forgot to crank the voltage up to max.
But I got enough stuck on there to loosen them a little, and it stayed put long enough for me to use the lumps to punch the races out.
Turned out to be a lot easier than I expected. I'd do it again if necessary.
caponerd is offline   Reply With Quote
Old 04-20-2014, 08:58 AM   #2
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,527
Heh. Turn up the heat, and turn down the wire feed. You got no penetration there.
GOOD JOB. Looks just like my first 'weld'.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 04-20-2014, 09:36 AM   #3
Twin headlight Ernie
bar napkin engineering
Oddometer: 1,488
Bearing race
I have been welding most of my life. The majority of welding I do these days is on bikes and hot rods.
The way I have done this is to use a fender washer with an OD that drops about halfway into the race. Weld the washer in place. Usually four or five short beads are enough. The heat does most of the work. Put a slide hammer through the hole in the fender washer and a couple of light taps pops it right out.
2HE
Motorcycles are my life.
Not my lifestyle.
My Smugmug:
http://twinheadlighternie.smugmug.com/
Dakota Motorsports
Twin headlight Ernie is offline   Reply With Quote
Old 04-20-2014, 09:42 AM   #4
Kai Ju
Kai Ju's Avatar
Oddometer: 1,893
2HE
That ought to go in Tips and Tricks, thanks.
Kai Ju is offline   Reply With Quote
Old 04-20-2014, 09:52 AM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,190
2HE
Bingo^2. One of the best solutions I've heard. Especially for the noob welder.
--Bill
'73 R60/5 Toaster
Old 04-21-2014, 08:26 AM   #6
Beater
Beater's Avatar
Oddometer: 3,527
SPOT ON. Never thought of that. THANKS!!!
2HE
Old 04-21-2014, 12:12 PM   #7
FrankR80GS
Oddometer: 337
Well, bearing races are 100Cr6, that's high carbon steel with 1%Cr. Not the easiest start for beginners.
FrankR80GS is offline   Reply With Quote
Old 04-21-2014, 12:52 PM   #8
SloMo228
World Class Cheapass
Oddometer: 1,826
2HE
That would have been faster than what I did last weekend to get my rear wheel bearing out on my DR350:
If I'd have just done this first thing instead of messing around with a punch trying to drive it out the normal way, I'd have saved myself 45 minutes of frustration.
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 04-21-2014, 12:58 PM   #9
supershaft
because I can
Oddometer: 9,116
It's easiest just to lay a bead around the race. They fall right out. No need to weld anything to them. The hardness of the race has nothing to do with it.
Old 04-21-2014, 04:33 PM   #10
r60man
r60man's Avatar
Oddometer: 484
I have done it this way. I tack welded a steel nail that I cut to fit about the middle of the race. I then use a long segment of pipe through the top/bottom and drive them right out.
I have since bought the cycleworks kit and for the money I think it is a lot easier and there is no need to worry about welding the race into the frame like a friend of mine did.
K1100RS, R75/6
Speed doesn't kill anyone, suddenly becoming stationary, that's what gets you - Jeremy Clarkson
r60man is offline   Reply With Quote
Old 04-21-2014, 06:39 PM   #11
caponerd OP
caponerd's Avatar
Oddometer: 1,980
2HE
Great trick. I could manage that, even with my present poor skill level.
Old 04-21-2014, 06:41 PM   #12
caponerd OP
caponerd's Avatar
Oddometer: 1,980
That was my biggest worry. Turned out ok, even on the lower race where my visibility was pretty restricted.
Old 04-22-2014, 12:49 AM   #13
ME 109
ME 109's Avatar
Oddometer: 3,039
That's a cheap race frame!
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 04-22-2014, 11:03 PM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,237
How did you remove the lower inner race from the bottom tree?
Old 04-22-2014, 11:45 PM   #15
RagerToo
vroom vroom
Oddometer: 303
What really helped me was doubling up on the reading glasses under the hood. Doggone, I got much better at dat' weldin'.
'80 R100RS but nekkid
Some folks still insist on going to a gun fight with a popsicle stick sharpened on the driveway.
RagerToo is offline   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
