Old 04-21-2014, 11:57 AM   #1
JGT OP
Oddometer: 223
/5 centerstand usage
Perhaps my centerstand spring is not right, or maybe I'm just uncoordinated.
When I roll the bike off the stand, it does not retract. It is still touching the ground. Is that correct, or should it snap up when the bike rolls forward and off the stand?
With the stand still touching the ground, it is awkward to hold the bike up and get the stand retracted using one foot.
Just wondering if I'm doing something wrong and there is a more elegant way to make this work.
JGT is offline   Reply With Quote
Old 04-21-2014, 12:25 PM   #2
Kanticoy
Oddometer: 331
Welcome to airhead center stands. That's just the way they work! Takes a little getting used to coming from a Japanese bike background but before long it'll be second nature. It is also compounded if the tang is broken from the side of the stand (which most of them are).
Kanticoy is offline   Reply With Quote
Old 04-21-2014, 12:36 PM   #3
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 559
Thumb Good information to add
Also do not sit on your bike when on the Centerstand
Airhead
1974 R75/6 for sale & 1989 R100GS & 1983 Honda CB1000
Biebs is offline   Reply With Quote
Old 04-21-2014, 12:40 PM   #4
JGT OP
Oddometer: 223
I'm not sitting on it, and the tang is not broken. So perhaps that's just how it is. I can push it up into the "up" position using the tang. It's just kind of awkward and a couple of times I've almost dropped the bike standing on one leg to do this.
Old 04-21-2014, 12:42 PM   #5
blaine.hale
blaine.hale's Avatar
Oddometer: 3,267
As kanticoy said, that's normal behavior. 2-stage deployment, as I call it.
Grab your little side handle, throw it off the stand and kick the stand up then get on and ride away. Simple, just takes some getting used to.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is offline   Reply With Quote
Old 04-21-2014, 03:46 PM   #6
JustinLonghorn
Oddometer: 49
And try not to roll it over your back foot.
JustinLonghorn is offline   Reply With Quote
Old 04-21-2014, 08:28 PM   #7
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,674
It'll likely spring into the up position the first bump you hit. Try just riding off with it still down a few times and monitor its behaviour.
You may not need to worry about tipping the bike if the flick back with your foot is awkward. Practice makes better though.
boxerboy81 is offline   Reply With Quote
Old 04-21-2014, 09:19 PM   #8
Thorazine
Likes exhaust fumes
Thorazine's Avatar
Location: Smoggy Valley, east of Smog City, Southern Calif.
Oddometer: 908
I love that solid pig iron sound it makes when it thunks down on the pavement.
Bones aren't important; we like motorcycles.-- My boy D @ 4 y/o
* Posts submitted under the moniker Thorazine are for entertainment purposes only, and may include exaggerations, prevarications or bald-faced lies. -- Thorazine - '74 R90/6
Thorazine is online now   Reply With Quote
Old 04-22-2014, 05:41 AM   #9
dm635
I Roll
Oddometer: 382
Never heard that. What's issue?
1978 R80/7
dm635 is offline   Reply With Quote
Old 04-22-2014, 10:50 AM   #10
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,072
The bad part about sitting on the bike when you push it off the center stand is when you get it part way off the stand and you loose your footing or a foot slips and it doesn't go off the stand. Instead, the bike falls back onto the stand and bangs the stops. Doing this a few times not only damages the stops but it will also bend the stand. For those of you who push the bike off the center stand while sitting on it and say "Oh it never falls back on the stand!" you are only fooling yourself.
Another thing to watch out for or to add to your maintenance list, is keeping the center stand bolts tight. Each time you pull the bike up onto it's center stand, the stand pivots try to tighten the left mounting bolt while trying to loosen the right one. I find the right center stand mounting bolt loose on almost every bike I work on.
Pokie is offline   Reply With Quote
Times are GMT -7.   It's 08:32 PM.
