Old 05-08-2014, 06:43 AM   #31
Bowber
Oddometer: 178
Yes I've done it but with a DR350 that'd done loads of miles, and it was a last ditch attempt to see if it was the valve stem seals leaking oil before I took it to bits.
Use band new string/rope not some that's been laying around getting dirty.
Steve
Bowber is offline   Reply With Quote
Old 05-08-2014, 07:38 PM   #32
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 772
The Dacron does not compress very well that's why it works, you can also use Kevlar Pull cord from a electrician supply house, its very stiff as well.
Random tip of the day,, Electricians pull cord is great for carrying for pulling stuff out of holes and such.. the 1/4 inch stuff is hell for stout and you can put a bunch of it in a tuna can size container..
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 05-08-2014, 10:55 PM   #33
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Its possible to swap seals without removing the heads...
Roll it to tdc, install a compression tester hose in the plug hole and connect the other side to compressed air. Pressurize the cylinder 35lbs or so. Place the spring under a press, depress and remove keeps. Pull apart, add new seal, do the rest.
Sporting Wood is offline   Reply With Quote
Old 05-09-2014, 02:47 PM   #34
Peanuts
Peanuts's Avatar
Oddometer: 1,640
Some random points which may help....
The KTM manual is a really good step by step manual.
I find it easier to mark the flywheel for tdc front and tdc rear against a mark on the neighbouring crank case, makes it easy when turning the crank to the next tdc.
The tappet buckets are in a deep pocket which must not be marked by your valve spring compressor, make sure there are no sharp edges.
You need a 46mm or 1 13/16" AF socket for the balancer shaft nut.
Check the camchain tensioner gap as per the manual to see how worn are your chains.
Piston rings have a mark on the top, a dot or circle.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 04:41 PM.
