Old 04-22-2014, 12:03 AM   #1
Jwcasillas OP
Oddometer: 43
Bmw r90/6 top end, transmission rebuild
I'm overhauling my daily rider for a trip to Colorado in mid June. I've been working on it for a solid 10 hour day now an will add pictures tommorow this is a list of what I'm doing, top end rebuild, transmission rebuild, clutch, fork rebuild carb rebuilds, electrical system freshening up, front brake system overhaul, greasing bearings and general poking around of anything else. I am doing all the work myself and posting pics and updates here, should make for some entertaining photos. Cheers
Jwcasillas is offline   Reply With Quote
Old 04-22-2014, 12:18 AM   #2
DiabloADV
Semi-Occasional
Oddometer: 2,275
Doing head work too? How so...?
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 04-22-2014, 12:45 AM   #3
Jwcasillas OP
Oddometer: 43
When I was 16 I worked at a cylinder head shop. All I am doing is replacing guides and lapping valves my seats are great. Might polish as well.
Old 04-22-2014, 01:02 AM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,356
It may only need valve guides but you won't know till the heads are apart. If it has BMW parts now then BMW parts should be used. Cylinder head work is usually considered specialized these days and not done by most riders. Not many years ago the riders did do more of this work.
There are a couple of special tools needed to even get the transmission apart. You should have access to a large shop press. Standard 20 ton usually works.
This is a lot of work you list. I think I got the idea, a rebuilt bike is what you want, so you are doing a years worth of work in 1 month?
The problem with projects of such a large scope is that bugs aren't worked out of one system before the next system is taken apart. So when the inevitable problems pop up they become difficult to diagnose.
Good Luck. I hope you get to make this trip.
---Albert Einstein
disston is online now   Reply With Quote
Old 04-22-2014, 02:41 PM   #5
Jwcasillas OP
Oddometer: 43
I am supported by a group of old school mechanics, the transmission is already rebuilt, the heads are apart and cleaned, I mic'd the bores at 90.18 and they are almost completely round so I honed them and will install rings whenever SFO bmw sees fit to get them to me. I gathered my parts and got my ducks in a row before I started this. The seats look like somebody in the past replaced them with hardened ones as they are almost flawless. The guides however are original and leaking mildly. I will probably do a YouTube video of me doing the guides and lapping the valves. This is my 5th airhead I have done all these jobs before with the exception of the forks; just not on the same bike at the same time. This is an every day rider with 90,000 miles. It is my transportation so I won't have it out of commission long. This will not be a show bike and I will not be spending massive amounts of cash on it as I would be better served getting a new machine. In short I am very practical about what I'm in the middle of. Photographic evidence will be posted this evening
Old 04-22-2014, 11:28 PM   #6
Jwcasillas OP
Oddometer: 43
I'm not saying there isn't any voodoo magic required in mechanical work but what bugs are you referring to? In my limited experience mechanical things function or don't a 90 tooth gear will always make a 30 tooth gear spin three times faster. If it doesn't it needs replacing. I am following the shop manual, the advice of Dave Gardener, Ted Porter, Dick Sullivan, and Robert Fleischer. I know this is do able right.
Old 04-23-2014, 12:29 AM   #7
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,545
Sounds like you're all over it and have about the best support one could ask for, keep us in the loop.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 04-23-2014, 10:29 AM   #8
SculptD
Smells like tech
Oddometer: 464
Originally Posted by Bill Harris View Post
There is more to transmission repair than knocking it apart and replacing parts. There are things that need it be done that require the knowledge acquired through experience. Not enough gotten by following Internet advice, a Clymer's and having a knack.
--Bill
While I don't quibble with the gist of this as far as the specifics of airhead transmissions, I do quibble plenty with it as a general philosophy.
How is one to get experience? Whatever will we all do when the gurus are all dead, and only the completely inadequate remnants of their web musings remain?
I work with college students, and as the years go by I find them more and more paralyzed by the need to be told what to do by an expert before they will do anything. That's not how I got to know what I do, and I bet many an airhead guru learned the bulk of what they know by plowing right ahead on their own and making heaps of mistakes along the way. Anybody who tells me about the "right" or "best" way to do something gains my immediate suspicion. By the advice expressed above, my winter rebuild should have been mostly sent out to various shops. All I need do is sign the checks. What would I have then gained? An impoverished experience.
Anyway, I don't get it, as the OP seems to have a whole lot of experience.
R75/5 SWB, Aprilia Falco. Both compulsively modified. And an R100s is on the way.
SculptD is offline   Reply With Quote
Old 04-23-2014, 03:50 PM   #9
Jwcasillas OP
Oddometer: 43
Here is my bike
Old 04-23-2014, 03:51 PM   #10
Jwcasillas OP
Oddometer: 43
clutch bolt destroyed by yours truly
Old 04-23-2014, 03:54 PM   #11
Jwcasillas OP
Oddometer: 43
honed the cylinders last night there are smooth spots where the rings are but i wouldnt hone ant more or risk giong out of round
Old 04-23-2014, 03:57 PM   #12
Jwcasillas OP
Oddometer: 43
bore is 90.18mm and not too out of round
Old 04-23-2014, 04:00 PM   #13
Jwcasillas OP
Oddometer: 43
I am not replacing these I will true them with a sharpening stone and tempered glass as a true reference. I have done this on cars quite a bit. after i do that i will use a rotary scoring brush to crosshatch for even wear characteristics. i am only changing the diaphram spring and the friction material.
Old 04-23-2014, 04:01 PM   #14
Jwcasillas OP
Oddometer: 43
1
Old 04-23-2014, 04:02 PM   #15
Jwcasillas OP
Oddometer: 43
what your piston sees
Times are GMT -7.   It's 06:36 PM.
