Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-26-2014, 12:42 AM   #106
Bluesilver
Bluesilver's Avatar
Oddometer: 340
Originally Posted by RobZorba View Post
Thanks for the warning - I'm not gonna do it.
I used this on my R1 Race bike but on Ti headers and it worked GREAT...for the track then, it rains and what a pig, bike looked like it was angry, steam coming from EVERY WHERE, my visor could see shyte...but yes, it will corrode your mild steel headers quick, not sure how much damage it will do to S/S over time though, does make the pipe run a lot hotter.
Every V-Twin Superbike I've had and now this Adventure which is a Superbike motor all suffer from the same problem, heat between your legs. Depending on the position of the rear cylinder and header down pipe the heat will hit you. Ducati with it's brilliant 1199 has a free ass warmer looking at the rear header pipe design under the seat and they have the exact same problem.
Consensus is, these bikes will cook your nuts when you in traffic or on a HOT day...all you can do is limit the radiation by fitting a shield like WINGS has or if there is space, tac wield a heat shield on the rear downpipe if there is space, again depends on the design of the bike.
I've learned to live with it as see it as part of the "charm" a v-twin has.
Bluesilver is offline   Reply With Quote
Old 05-27-2014, 12:40 AM   #107
Davy F
Pro Goolie Fiddler
Davy F's Avatar
Oddometer: 271
I've ridden quite a few V twins, but my 1190 is the only one I've experienced cooking thighs on. Really looking forward to my Wings coolers.
Good luck exploring the infinate abbyss !
Davy F is offline   Reply With Quote
Old 05-27-2014, 03:08 AM   #108
Reddydr
Oddometer: 64
new seat cooler
Hi thanks guys its working and looks good as part of OE equipments
Reddydr is offline   Reply With Quote
Old 05-28-2014, 07:19 AM   #109
nvdesertrat
Nevada Desert Rat
nvdesertrat's Avatar
Oddometer: 211
Originally Posted by nvdesertrat View Post
Just got them installed with tank bag.
UPDATE: These are working great I am currently on my way down to Cabo and have gone through 102 degree heat with no real discomfort so there ya go
Doug
2009 KTM 990 Adventure R
2014 KTM 500 EXC
2014 KTM 1190 Adventure R
nvdesertrat is offline   Reply With Quote
Old 05-28-2014, 08:52 AM   #110
Bluesilver
Bluesilver's Avatar
Oddometer: 340
My 996SPS in traffic was interesting, same for the old TLR1000R, my 2 vrods were the first bikes to be 'cool' to the nuts...but my RXV450 COOKED my ass with the pipe running under my ass...so much so the seat melted...
Old 05-28-2014, 05:10 PM   #111
BHoward
BHoward's Avatar
Oddometer: 122
Seat cooler installed.
BHoward is offline   Reply With Quote
Old 05-28-2014, 05:13 PM   #112
BHoward
BHoward's Avatar
Oddometer: 122
Seat cooler.
Old 05-28-2014, 05:22 PM   #113
mvonkaenel
Roost Hog or Die
mvonkaenel's Avatar
Oddometer: 389
Cooler
Those look like OEM panels. Very nice.
I am still concerned with trapping the heat in there.
I have the same model/color bike and close to pulling the trigger.
I want the pipe too, to go with it.
'98 ATK605
'07 Yam WR450F
'07 Yam XT225
'14 KTM 1190 Std.
mvonkaenel is offline   Reply With Quote
Old 05-28-2014, 05:28 PM   #114
BHoward
BHoward's Avatar
Oddometer: 122
When you e-mail Gorazd and tell him you want both the seat coolers and the muffler maybe he will discount the price a little for getting both.
Old 05-28-2014, 06:24 PM   #115
NoSpam
Oddometer: 168
Originally Posted by BHoward View Post
Seat cooler.
Looks awesome! You added some understated upgrades that really look nice.
NoSpam screwed with this post 05-28-2014 at 06:26 PM Reason: sp
NoSpam is offline   Reply With Quote
Old 05-28-2014, 06:31 PM   #116
BHoward
BHoward's Avatar
Oddometer: 122
Thank you
Old 05-28-2014, 10:36 PM   #117
Bluesilver
Bluesilver's Avatar
Oddometer: 340
Thank you
How are you guys wiring in the driving lights, separate switch or a relay and connected to the headlights?
I/m looking at the WINGS cooler panels as their pipe is brilliant...let us know how the panels perform over time.....
Old 05-28-2014, 11:04 PM   #118
Davy F
Pro Goolie Fiddler
Davy F's Avatar
Oddometer: 271
Very nice, BH. Are those SW-Motech aux light brackets ?
Old 05-29-2014, 07:09 AM   #119
BHoward
BHoward's Avatar
Oddometer: 122
I used ADVmonster's wireless dimmer ( http://stores.advmonster.com/waterpr...h-beam-bypass/ ).
The dimmer and the relay fit perfect behind the headlight.
I used the 1 amp switched power and the 10 amp constant power behind the headlight. The 1 amp to turn on a relay and the 10 amp to power it. Also tapped into the high beam wire to turn the LED's up to 100% when I turn on the high beam. I normally keep them around 50%.
So I have no external switches, just a remote I keep in the dash cubby hole. The lights are on when the bike is on.
The Wings seat coolers are great, the heat on my inside leg is reduced to almost nothing.
Old 05-29-2014, 07:09 AM   #120
BHoward
BHoward's Avatar
Oddometer: 122
Yes. They are very nice.
Times are GMT -7.   It's 11:49 PM.
