Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 04-26-2014, 06:46 AM   #1
ebrew OP
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
1190 black dog skid plate
If anyone got it please let me know how it goes for you ( fit wise)
Thanx
ebrew is online now   Reply With Quote
Old 04-27-2014, 06:23 AM   #2
ebrew OP
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
All good
In the hood
Old 04-27-2014, 10:49 AM   #3
Doug Matson
Doug Matson's Avatar
Oddometer: 1,859
I just got one and it fits good and is very protective! The quality is first rate! I like the side stand relocation kit also, very strong
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 04-27-2014, 10:59 AM   #4
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 544
Are those highway pegs?
Do you like the wide pegs? I am thinking of those, the damn passenger pegs are in my way when off-road and on the pegs. I would get rid of them, but ride two up with my wife once or twice a week. So if I can get my feet out a bit, maybe that will work?
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Old 04-27-2014, 09:02 PM   #5
Doug Matson
Oddometer: 1,859
I really like the pegs and yes those are highway pegs i got from Adventure
Designs I think. The end unscrews and it is water tight so you can store little things in there.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 04-28-2014, 07:20 PM   #6
Black Hills
Oddometer: 1,184
Fitted mine today, looks way better than the touratech one I had. I had a little trouble getting it to fit between the rear mounts, seemed to wide but a few "adjustments" with a 5lb dead blow and all is well? It did say to use the 4 8x25mm bolts for mounting but mine came with 2 25's and 2 20's I put the short ones in the front? All in all very happy with it.
Black Hills is offline   Reply With Quote
Old 04-28-2014, 08:18 PM   #7
coloktmGS
Oddometer: 312
Mine also came with 2 25's ans 2 20's. It did however come with 4 30's (the black ones) which I used. Which ones are correct?
coloktmGS is offline   Reply With Quote
Old 04-28-2014, 08:38 PM   #8
Black Hills
Oddometer: 1,184
I think the 30's are for the foot peg mounts
Old 04-28-2014, 08:41 PM   #9
ebrew OP
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
I put the shorter ones
Up front ( less room behind ) and the longer ones on the rear mounts
Old 04-28-2014, 08:41 PM   #10
Doug Matson
Oddometer: 1,859
The only black ones that came with mine were the ones that remounted the foot peg brackets back to the frame
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 04-28-2014, 09:46 PM   #11
DirtJack
DirtJack's Avatar
Oddometer: 1,525
Here's a post I made to the 2014 1190 thread.
Back on January 20, I ordered one of these.
It finally came this afternoon and I put it on. The installation is a bit fiddley and you have to disable the side stand switch (which I usually do anyway so I don't have a problem with the Hall effect switch on the trail). The plate is 5.33 mm thick (including powder coat on both sides) and seems, because of its size, a bit lighter than I expected. We'll see how it holds up. The installation includes a side stand relocation to the frame which seems to be quite sturdy. The powder coat/paint of the new mount had to be cleaned out of the side stand bearing to do the install because the tolerances are quite close. The installation requires that you finally mount the plate with the four mounting points very loose. Then tighten the 4 mounting bolts and everything else (including the foot peg mounts). I hope the plate will come off/on without loosening everything because putting the foot pegs back on can be a bit of a pain (particularly for an oil change). We'll see. I'm happy so far.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-28-2014, 09:50 PM   #12
DirtJack
DirtJack's Avatar
Oddometer: 1,525
Thanx
I did some measurements of the flat part on the bottom with the bike on the center stand. I didn't notice the differences when looking one side at a time.
At the back (under rear screw) 10 7/8" (left) 11 1/4" right. Maybe it has something to do with pipe clearance or the center stand, but the difference is strange. You don't notice because it is hard to see both sides at once. At the front 11 3/8" (left) 11 5/8" (right).
2008 KTM 690 Enduro
Old 04-29-2014, 09:34 AM   #13
Black Hills
Oddometer: 1,184
zip tie the spring together and its easy....
Old 04-29-2014, 09:44 AM   #14
strider.deano
Oddometer: 333
The zip tie works but BDCW includes a short metal dowel that you insert in the spring. Then just set the spring in the peg, force the peg and spring into place and when you push the pin in, it displaces the dowel. I'm adding the dowel to my tool kit. Easy Peasy!
strider.deano is offline   Reply With Quote
Old 04-29-2014, 09:52 AM   #15
strider.deano
Oddometer: 333
Same issue for me (I started looking for a bigger hammer) until I read Kurt's instructions...."Don't tighten bolts until the end!" when I loosened the left peg mount bolts up, the two back skid plate bolts lined up perfectly. The only issue I have with the skid plate is that it's got quite a echo when a rock kicks up. I'll add a bit of firewall material at the next oil change.
Great Job Kurt!
Times are GMT -7.   It's 08:09 PM.
