Old 04-29-2014, 06:47 PM   #1
renogeorge OP
Oddometer: 1,433
New Idea For Single Front Brake??
I have recently been researching a change to a single front (without ABS) caliper and disc for my 2007 with ABS. There are several great threads on this topic. The "why?" question has been beaten to death. If you don't get the reason or don't agree with the thinking, that's OK.
Possibly a new approach with lower cost that the 4 piston Moto Master caliper setup? I am getting great reports on the performance of the 2014 690 Enduro, single disc setup. Yes it is a lighter bike with an Enduro slant. But, I am hearing that it has a great feel and good on-road stopping power. With the help of Mark at NMS in Reno, I have been researching part numbers.
The 690 Enduro uses a different master cylinder with a caliper that is the part number which KTM has superceded to for the 2007 Adventure. It calls for different sized pistons--30 and 32 mm. I don't know if the original 2007 Adventure caliper used this setup or not.
The 690 also uses a master cylinder which is a completely different part number when compared to the 990.
I am thinking about a lower cost option to get to a single disc, non-ABS setup for my 2007 990 Adventure. I want to lose the weight and complexity of ABS but maintain decent on road stopping power.
In a "money is no object" world, I would order up the 690 master and caliper, source some non-ABS brake lines and charge ahead.
Before I do that, I thought I would see if anyone had thoughts on the 690 Enduro's brake performance. And whether or not there is any real difference between the 690/original 990/new 990 part caliper. And the master cylinders too.
Any thoughts???
KTMs--300, 518, 990
renogeorge is online now   Reply With Quote
Old 04-29-2014, 07:00 PM   #2
sieg
sieg's Avatar
Oddometer: 2,901
My thoughts..........you think to much.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 04-29-2014, 07:07 PM   #3
renogeorge OP
Oddometer: 1,433
Good thinking??
KTMs--300, 518, 990
Old 04-29-2014, 07:37 PM   #4
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 972
Originally Posted by renogeorge View Post
Good thinking??
Not exactly.
whisperquiet is offline   Reply With Quote
Old 04-29-2014, 07:43 PM   #5
renogeorge OP
Oddometer: 1,433
You Illinois guys think alike. Ever ride your Adventure's off road? Ever check out the 990 Adventure Baja model? Sorry if you don't get it....
KTMs--300, 518, 990
Old 04-29-2014, 07:47 PM   #6
zgfiredude
Oddometer: 866
I'd be interested in your findings. I have a non-ABS 950 and have gone to one brake.......
I will watch this with interest.
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is offline   Reply With Quote
Old 04-29-2014, 07:52 PM   #7
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 733
Why not just get the Baja front brake set-up? No thinking necessary.
HeatXfer is offline   Reply With Quote
Old 04-29-2014, 07:58 PM   #8
renogeorge OP
Oddometer: 1,433
Trying to understand the difference between the different KTM single disc setup components--master cylinders and calipers. But the answer to your question is $$$$$ Caliper and master is $400+ for 690 and almost $600 for 990 Baja. Due to superceded part numbers and short part descriptions, I am still not sure which components are different than the 990 dual disc setup on my 990.
And I have not personally tried the 690 or the Baja 990 single disc.
KTMs--300, 518, 990
Old 04-29-2014, 08:27 PM   #9
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,031
Or throw the SE caliper + master into the mix
dogsslober is online now   Reply With Quote
Old 04-29-2014, 09:32 PM   #10
rburkat
rburkat's Avatar
Oddometer: 294
Just put on the master from the SE to get the right feel. Keep the stock 990 caliper. This has worked perfectly for me for the last couple of years.
Cheap
$106 63013001000
http://www.ktmpartshouse.com/fiche_s...er=63013001000
rburkat is offline   Reply With Quote
Old 04-29-2014, 10:05 PM   #11
dewe74
dewe74's Avatar
Oddometer: 112
Cheap
$106 63013001000
Agree. Same setup for me.
dewe74 is offline   Reply With Quote
Old 04-29-2014, 10:06 PM   #12
Bartek990
Oddometer: 62
[QUOTE=rburkat;24053644]Just put on the master from the SE to get the right feel. Keep the stock 990 caliper.
+1
SE Master all the rest stock .
Bartek
Bartek990 is offline   Reply With Quote
Old 04-29-2014, 10:17 PM   #13
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,486
This
“Men marry women with the hope they will never change. Women marry men with the hope they will change. Invariably they are both disappointed.”
― Albert Einstein
dlrides is offline   Reply With Quote
Old 04-29-2014, 10:45 PM   #14
chasbo
chasbo's Avatar
Oddometer: 1,708
Cheap
$106 63013001000
Definitely the easiest way to do your conversion. If you find you really like it, then you can consider investing the big bucks into a Motomaster setup.
You can outdistance that which is running after you,
but not what is running inside of you
chasbo is offline   Reply With Quote
Old 04-30-2014, 06:18 AM   #15
renogeorge OP
Oddometer: 1,433
Thanks guys. I was aware of the SE option and the Moto Master. I haven't been able to try the SE setup and without doing so had been looking for a mid option--better on road braking than the SE but cheaper than the MM.
Guess I'll review the different masters and order up one. Anybody able to comment on SE vs Baja brake performance?
KTMs--300, 518, 990
Times are GMT -7.   It's 04:48 PM.
