Old 04-30-2014, 02:51 PM   #16
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
George,
Ride up to Truckee and try my SE. SE master and stock caliper ith relocation bracket and 320mm disc. You'll be surprised, impressed, and it's not that expensive even with the disc.
Brent
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 04-30-2014, 07:58 PM   #17
renogeorge OP
Oddometer: 1,363
I need to do that. Where did you source the 320mm disc"
KTMs--300, 518, 990
renogeorge is online now   Reply With Quote
Old 04-30-2014, 08:07 PM   #18
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,920
which disc and bracket?
Which disc and adaptor bracket did you use?
Joe
Originally Posted by brents347 View Post
George,
Brent
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 04-30-2014, 08:13 PM   #19
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 869
Relocation bracket
Yea more info on the bracket??
dogsslober is offline   Reply With Quote
Old 04-30-2014, 08:53 PM   #20
dogsslober
dogsslober's Avatar
Oddometer: 869
Disk
"Braking" make's this rotor,STX54D, 320mm
Old 04-30-2014, 09:26 PM   #21
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,920
and..
is it a direct bolt on to the KTM950? and what is the adaptor bracket for the KTM950 ADV/SE?
Simpson Trip 2008
Old 04-30-2014, 09:28 PM   #22
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
The bracket I used is made by Braking. It is the POW 94, is available on Amazon and costs about $70. It fits both Adv's and SE's.
The disc I used was a 320 sold by PCC motors on Amazon. It is listed for KTM 350, 450, 525, etc. They are all the same and they are all the same as the big bikes. I paid $170. I also now use pads that fit the mid-2000's VFR800 Hondas and cost about $35.
All the 320mm rotors you see for the KTM 'little' dirt bikes also fit the big bikes. Direct bolt on.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 04-30-2014, 09:42 PM   #23
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,920
ok thanks.
sounds like a great solution, if you are using the standard calliper, why the VFR800 pads?
so to summarize, the POW 94 adaptor bracket, the 320mm disc, standard KTM950 ADV calliper and a 950/690 master cylinder, creates a good single disc solution?
Joe
Simpson Trip 2008
MymoJoe screwed with this post 04-30-2014 at 09:57 PM
Old 05-01-2014, 12:34 AM   #24
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
New Idea For Single Front Brake??
Joe
You more or less have it. I am using an SE master, which seems to be the single-disc ticket, and a stock SE caliper. I don't know if Adv and SE calipers are the same. The POW 94 bracket is for relocating on small bikes and on the big bikes it's new location of the caliper makes the stock 950/990 pads about 3mm too short in backing plate length. The VFR pads are identical, but about 6mm longer than the 950/990 pads, so they are 3mm TOO LONG and I shorten them by that distance with a file before installing.
Hope that clarifies a bit.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 05-01-2014, 03:49 AM   #25
DirtyADV
DirtyADV's Avatar
Oddometer: 2,234
Slightly different parts number:
60013015000 -06 SE
60013018000 -04 Adv
So not sure if there is any significant difference, might be different between years, just checked the two above.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 05-01-2014, 05:25 PM   #26
renogeorge OP
Oddometer: 1,363
The above pictured Braking rotor shows as not available on Amazon. What appears to be the same rotor, specified for the smaller KTM singles and with with mounting bracket, is available from China for $189 here:
http://www.ebay.com/itm/Oversize-Fro...p2054897.l4275
I ordered one and should have it 5/7. I will fit things up and report back
KTMs--300, 518, 990
renogeorge screwed with this post 05-01-2014 at 10:22 PM
Old 05-01-2014, 08:23 PM   #27
FZcruzer
Oddometer: 496
Originally Posted by renogeorge View Post
Trying to understand the difference between the different KTM single disc setup components--master cylinders and calipers. But the answer to your question is $$$$$ Caliper and master is $400+ for 690 and almost $600 for 990 Baja. Due to superceded part numbers and short part descriptions, I am still not sure which components are different than the 990 dual disc setup on my 990.
And I have not personally tried the 690 or the Baja 990 single disc.
I am interested in converting to a single disc setup but can't compromise braking power, need the cake and icing too.
My 990A front rim is demolished and needs to be replaced so thinking of getting an SE rim and looking at brake options.
You guys have used the 990 Baja as an example of a possible donor but it is a dual disc setup same as what we have unless I am missing something.
FZcruzer is offline   Reply With Quote
Old 05-01-2014, 10:24 PM   #28
renogeorge OP
Oddometer: 1,363
Yep. I was wrong on the Baja--sorry. I am pursuing oversize rotor with Adventure caliper and SE or 690 Enduro master. Not really a new idea as it is turning out. Thanks to those who offered their experiences and expertise!
KTMs--300, 518, 990
Old 05-15-2014, 08:35 AM   #29
renogeorge OP
Oddometer: 1,363
OK. Partial update.....I got the E bay 320 mm disc and caliper bracket.
The Adventure caliper will NOT fit the bracket. The caliper that fits is the older (pre='09?) dirt bike part. It bolts right up. Nice looking parts.
Still waiting for brake lines I need as I am removing ABS at same time I go to single disc. Gonna see what I have with this setup and Adventure front master. May still end up changing that.
FWIW
KTMs--300, 518, 990
Old 05-15-2014, 10:19 AM   #30
Tom_C
pinned underneath
Oddometer: 117
Reno, quick question for you. The ebay rotor and bracket list for $189, and that includes shipping, but the seller states that the buyer is responsible for all import duties and taxes, and that they are collected by the shipping company or when you pick the product up. How did that part work, and what were the fees?
07 KTM 950 Super Enduro R pilot -lunatic fringe 1%er of the gravel travel ADV crowd.
Tom_C is offline   Reply With Quote
Times are GMT -7.   It's 10:25 AM.
