Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 05-16-2014, 10:13 AM   #61
ttpete
Rectum Non Bustibus
Oddometer: 6,159
Originally Posted by markk53 View Post
I take it that was the factory frame on that one to the viewer's left (speaker's right) in the video. I wondered if it was stock or modified since a lot of them (most every image I've seen) had the dual enclosed springs. Did Vincent use an open coil/over or enclosed?
Seems you can get images of everything BUT the rear suspension set up. I did find one that appeared to have something like a damper between the spring cases, but the darn school filter won't let me view the image (huge image too) and by the time I go home I forget.
Regardless, it is still enjoyable to me at least, to banter a bit and learn something else. Thanks.
Open coil-over. It's horizontal and up under the tank. Series D bikes are different than the B&C series.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 05-16-2014, 12:04 PM   #62
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,217
Must be most of the bikes pictured on-line are Bs and Cs. Thanks.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 05-16-2014, 03:55 PM   #63
k-moe
k-moe's Avatar
Oddometer: 3,080
There were very few D series bikes produced. C is the most common.
Mixing metaphors is like killing two birds with a dog that won't hunt.
k-moe is online now   Reply With Quote
Old 05-18-2014, 07:25 AM   #64
markk53
markk53's Avatar
Oddometer: 9,217
Originally Posted by doxiedog View Post
Why does a single shock cost twice as much,as a pair of shocks?
It doesn't, it usually costs 2-1/2 times as much from what I've seen... go figure!
Mark - klx678
Old 05-18-2014, 04:10 PM   #65
ttpete
Rectum Non Bustibus
Oddometer: 6,159
Go price a pair of Ohlins twin shocks and see. You get what you pay for.
Old 05-19-2014, 06:03 AM   #66
markk53
markk53's Avatar
Oddometer: 9,217
How do they compare to the Ohlins single of similar quality? Quick look found twin shocks w/reservoirs were around $730, singles around $942. So it's even nearly true with Ohlins too.
In general, though, a decent set of twin shocks are around $350 ($175/shock), where a similar quality single will run around $450-500.
Mark - klx678
Old 05-19-2014, 02:38 PM   #67
k-moe
k-moe's Avatar
Oddometer: 3,080
A fair amount of that price diffrence is attributable to monoshocks being a smaller (and less universal) market. Lower volume products always cost more.
Old 05-20-2014, 05:58 AM   #68
markk53
markk53's Avatar
Oddometer: 9,217
Never really thought about it, but I definitely have to agree. Especially when fitting a piggy back reservoir. With twin shocks, it's different eyelets and maybe different lengths, but still only use a few body sizes.
So now we have an idea why the single shock is more than the twin shock set.
Mark - klx678
Old 05-20-2014, 10:19 AM   #69
ttpete
Rectum Non Bustibus
Oddometer: 6,159
Monos are often more sophisticated than the twins with features like knob adjusted damping and hydraulic preload adjusters. It's nice to be able to twist a knob and compensate for a passenger.
Old 05-20-2014, 03:28 PM   #70
markk53
markk53's Avatar
Oddometer: 9,217
Well, it is a breeze to adjust preload on two shocks on the sides and then there is the trick little lever set up that WP uses on their shocks to lock out the light spring when riders go two up. It is their Adjusable Rate Suspension:
They put these caps on over the light rate spring wit a lever that hits the cup. In any of the four positions the lever alters when the heavier spring takes action as the lighter rate spring becomes blocked out of action. Simple functional and seconds to do it.
It can be a lot simpler when the shock isn't buried in the center of the bike too.
Mark - klx678
Old 07-26-2014, 10:37 PM   #71
73Mustang
Oddometer: 439
I think dual shock frame is inherently stronger than single.
Because of the dual shock mount, you get a super strong subframe.
On other hand, I've seen a KLX subframe (single shock) snap like a tweeg.
So if your goal is to build a pack mule and hang all kinds of luggage on it, than dual shock is superior.
73Mustang is offline   Reply With Quote
Times are GMT -7.   It's 09:57 PM.
