Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-17-2014, 12:06 PM   #496
Ouroboros
Ouroboros's Avatar
Oddometer: 127
Originally Posted by Koolranch View Post
What grease??
The grease mentioned in the instructions but not included in the kit.
Ouroboros is offline   Reply With Quote
Old 06-17-2014, 12:20 PM   #497
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,091
I used this cause thats what I had :
No jokes please ; )
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 06-17-2014, 12:33 PM   #498
Koolranch
NCADVR
Koolranch's Avatar
Oddometer: 467
Well I didn't read the instructions.....
No jokes please ; )
Koolranch is online now   Reply With Quote
Old 06-17-2014, 01:01 PM   #499
Hilts
Oddometer: 40
My airbox story
I received my bike in early January, when the prevailing wisdom was that KTM had resolved the issue for 2014. The bike had around 4 or 5k miles when the first reports of 2014's having airbox issues started showing up so I told myself....."at least it is under warranty".
My bike has 7700 miles on it today and the airbox looks like the photos others have posted early in this thread. She scored 8% in the leak down test. KTM will be replacing the cylinders, pistons, rings, valves and etc. Their current resolution for the airbox is to install the KTM PowerParts air filter and dust covers for snorkels. The airbox lid is to be sealed with silicone when reassembled.
Hilts
Hilts is offline   Reply With Quote
Old 06-17-2014, 01:06 PM   #500
dragos
Belzebut
dragos's Avatar
Oddometer: 874
Ok, I thought someone here said they have a 44 rear sprocket mounted or did. If so where did you find it ?
For sure not in a thread about the airbox.
dragos is offline   Reply With Quote
Old 06-17-2014, 01:13 PM   #501
Ouroboros
Ouroboros's Avatar
Oddometer: 127
Since it is such a relatively easy procedure that requires such little time to check and clean the filter, how often are some of you checking and or cleaning the Unifilter. Yes I know it depends greatly on riding conditions. Just some examples would be of benefit. I intend on doing a check after approximately 500 miles of 25% dusty dirt roads and 75% road as a gauge for future maintenance.
Old 06-17-2014, 01:54 PM   #502
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,091
'09 BMW R1200GSA
Old 06-17-2014, 04:00 PM   #503
like2lean
Oddometer: 26
They've got to be kidding... who wants to spend 30 min cleaning old silicone off every time you want to check the filter.
My Uni came so wet with oil any grease I would have put on it would have slid right off. I think the pressure of the clamp just let the front of the filter slide right out and start sucking air. I checked and do have the right part #.
like2lean is offline   Reply With Quote
Old 06-17-2014, 08:38 PM   #504
Koolranch
NCADVR
Koolranch's Avatar
Oddometer: 467
Hilts
What where the symptoms that prompted the leak down test? I went on one very dusty ride and got it installed very quickly after that. It had less than1000 miles.
Old 06-17-2014, 08:57 PM   #505
Hilts
Oddometer: 40
I returned from a 2000 mile ride and decided it was time to inspect the filter. The inside of the box was dusty like the photos shown early in this thread. I photographed the dirt and took it to the dealer. They performed the leak down test without any argument based on the photos.
Hilts
Old 06-17-2014, 11:35 PM   #506
TDsurf
Orange Flyer
Oddometer: 87
How long did the test take and what was the outcome? What was your score?
Photo's would be appreciated.
TDsurf is offline   Reply With Quote
Old 06-18-2014, 10:53 AM   #507
Hilts
Oddometer: 40
The test should take a couple of hours. My bike's score was 8%.
Hilts
Old 06-18-2014, 12:35 PM   #508
Koolranch
NCADVR
Koolranch's Avatar
Oddometer: 467
Hilts
My box looked the same if not worse. I may pull it back apart and have another look now that I have some miles on it.
Old 06-18-2014, 02:01 PM   #509
Koolranch
NCADVR
Koolranch's Avatar
Oddometer: 467
Hilts
HILTS,
You said-
"KTM will be replacing the cylinders, pistons, rings, valves and etc. "
Are you saying they have committed this to you or are you hoping they do this?
What is the acceptable range for the leak down test?
Steve
Old 06-18-2014, 02:05 PM   #510
wilmar13
Oddometer: 662
HILTS,
You said-
Steve
It would be cool if they rebuild just in case, but I always thought rule of thumb was: anything less than 10% is good, 10-15% is acceptable, and after that start thinking about rebuild (above 20% needs rebuild).
Perhaps they are doing the right thing preemptively as 8% is higher than should be expected for newish engine.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Times are GMT -7.   It's 09:41 PM.
