Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-07-2014, 10:08 AM   #676
F650Dakar_Norway
What off-season?
F650Dakar_Norway's Avatar
Oddometer: 960
Nice feedback on the Uni. A mustHave
One thing: Can the self-tapping airbox bolts be replaced by proper nuts & bolts?
As Filterman has noted these self-tappers are gradually loosing their retaining capabilities after each use and will at some point loose their function over time.
Me reckon regular inspections of the filterbox innards and filter functionality is a must if you enjoy group riding and/or dusty conditions. After all the KTM marketing hype is directed towards sport riding dirt conditions.
Norway
Current stable:
2010 BMW F800GS
2008 KTM 690 RFR
1994 Honda ST1100
F650Dakar_Norway is offline   Reply With Quote
Old 07-07-2014, 06:16 PM   #677
exlogger
Oddometer: 35
What aout?
Is the Doohikey OK?
exlogger is offline   Reply With Quote
Old 07-07-2014, 06:57 PM   #678
Koolranch
NCADVR
Koolranch's Avatar
Oddometer: 482
Originally Posted by coloktmGS View Post
I think we all have this and if we ever forget...the GrandZorba will remind us that we should have it (or the atty's phone number on speed dial).
To help with that...I can offer this. I installed a Uni after having dirty butterflies. I first used the socks but then removed them as I also noticed a dulled performance. I then took the bike on a 1800+mile trip across the colorado Backcountry Discovery Route (650 miles+ of dirt) much of it on dusty roads riding 2nd or third in a line of bikes. When I got home, I removed the tank and filter to find this:
Untitled by coloktmGS, on Flickr
That final one is the 'dirty' side of the filter with the pre filter removed. All in all, butterflies and internals of box were spotless. This was a grueling environment for an air filter and success here has provided me with good piece of mind.
I did find it interesting that the dirt is focused on the lower half of the filter, right where previous videos showed the OEM filter flexing.
To anyone on the fence...buy the Uni and ride the damn thing...
Great report, I installed after I went on a dusty ride shortly after I purchased the bike. I'm going to pull it at 3000miles to have a look see.
Koolranch is offline   Reply With Quote
Old 07-07-2014, 07:01 PM   #679
BlueDownton
Oddometer: 26
Thanks for the update!
Great stuff there. Thanks for taking the time to show us the pics. Went on a ride yesterday in the mountains. Couldn't agree more about the bike!
BlueDownton is offline   Reply With Quote
Old 07-07-2014, 09:30 PM   #680
Bluesilver
Bluesilver's Avatar
Oddometer: 359
Very nice.....such a simple fix, could have been fitted from day 1 by KTM!
Thanks for the pics.
Bluesilver is offline   Reply With Quote
Old 07-07-2014, 09:34 PM   #681
nighthart
nighthart's Avatar
Oddometer: 18
Question
Probably because the snorkels direct the air to the lower half of the filters?
nighthart is offline   Reply With Quote
Old 07-07-2014, 09:48 PM   #682
motomuppet
Oddometer: 469
I suspect the air directed to that area by the snorkels has little to do with it. The turbulence and suction created in the airbox will have a far greater effect on where the greatest load is placed on the filter. Any thermodynamic rocket surgeons out there able to calculate the velocity of the air moving through the airfilter into the throttle bodies at WFO at 9000rpm in any gven gear?
Clearly an area KTM failed to research properly, even after two model years, but thankfully there is a simple fix that seems to work perfectly! Thanks for the images
motomuppet is offline   Reply With Quote
Old 07-08-2014, 11:56 AM   #683
JBird
Retriever
JBird's Avatar
Oddometer: 860
Originally Posted by f650dakar_norway View Post
one thing: Can the self-tapping airbox bolts be replaced by proper nuts & bolts?
+1
JBird
KTM 1190R
KTM 950SMR
'08 Goldwing
'98 Golden Retriever
JBird is offline   Reply With Quote
Old 07-08-2014, 12:03 PM   #684
Ouroboros
Ouroboros's Avatar
Oddometer: 138
Originally Posted by JBird View Post
+1
I was wondering that last week when I was checking my filter. I believe a nut and bolt could be used on the left side and the rear two screws. The right side would take more imagination due to the threaded portion being inside the box. But I was having a few beers at the time and it could be the other way around.
Ouroboros is offline   Reply With Quote
Old 07-08-2014, 12:05 PM   #685
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,436
IIRC it will be hard to get to the more forward screws to replace with nuts / bolts. I was thinking about this when I installed the Uni because 1 of my screws was stripped from the factory. I plan to pull my tank off in the next week or so and look things over closer. I've got a little over 1000 miles since the Uni.
PineyMountainRacing is offline   Reply With Quote
Old 07-08-2014, 12:35 PM   #686
PineyMountainRacing
Oops....
Oddometer: 2,436
exactly, that's how I remember it.
Old 07-08-2014, 12:52 PM   #687
dragos
Belzebut
dragos's Avatar
Oddometer: 1,132
Wouldn't it be possible to use some external clips / clamps?
dragos is offline   Reply With Quote
Old 07-08-2014, 12:55 PM   #688
PineyMountainRacing
Oops....
Oddometer: 2,436
IDK if there would be enough clearance between the clips and the bottom of the tank. I think it's pretty tight.
Old 07-08-2014, 02:31 PM   #689
kag
Wander Lust
kag's Avatar
Oddometer: 1,748
Looked at mine today. Want something other than the uni filter
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 07-08-2014, 04:54 PM   #690
Omaha Tenere
Oddometer: 22
How can one filter do so well and then another not do as well? Is there a difference in the air boxes or possibly the install method?
--No matter where you go, there you are!
Omaha Tenere is offline   Reply With Quote
Times are GMT -7.   It's 12:12 PM.
