Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-06-2014, 07:18 PM   #1
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
1190R front sprocket removal?
Posted this in the gearing thread, but I need some help! Trying to change from a 17 to a 16 front. Major PITA so far! but if I can't get the sprocket out! would advise anyone changing gearing to do the rear sprocket instead...
This might be a dumb question, but how do you get the front sprocket off? Mine appears to not be able to get past the groove in the swing arm. Like you would have to take the swing arm off the get the sprocket off. There has to be a trick, right? I'm disassembled to that point, and took a break to research and have a couple of beers to think about it. don't think I will get too far tonight!
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Old 05-06-2014, 07:21 PM   #2
irongrady
irongrady's Avatar
Oddometer: 241
Can you post up a pic? I'm sure you'll get some help if you do. As of now I can't picture what you're talking about.
irongrady is offline   Reply With Quote
Old 05-06-2014, 08:12 PM   #3
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
There is a groove in the swing arm that the sprocket runs in. I can't figure out how to get the teeth past that groove.
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-06-2014, 08:20 PM   #4
Black Hills
Oddometer: 1,323
It's a PIA but it does come off just keep wiggling it. I thought the 16 was too low so went back to stock and will try a 44 rear when I can find one?
Black Hills is offline   Reply With Quote
Old 05-07-2014, 11:27 AM   #5
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
Mine doesn't come off with wiggling. I'm surprised no one else has chimed in. I figured lot's of people would have changed this by now. Pretty stupid design is what I'm thinking, I hope it isn't the stupid mechanic!
I'm going at it tonight with my Dremel tools!
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-07-2014, 12:48 PM   #6
Black Hills
Oddometer: 1,323
make sure the chain is off the rear sprocket, line the teeth up so the chain guide on the swingarm is between two teeth and then pull on the top and bottom of the sprocket, wiggling it back and forth. just about the time your fingers go numb it should come off.
Old 05-07-2014, 01:36 PM   #7
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
Will make one more attempt tonight, but after 2 beers, the Dremel is coming out!
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-07-2014, 01:51 PM   #8
Black Hills
Oddometer: 1,323
it is a pain in the ass, if you could get the chain off it would help. I was about to give up when it just popped off?? maybe it was just luck? unfortunately I didn't like the 16 and had to change it again, the 16 does come off easier
Old 05-07-2014, 01:57 PM   #9
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
My chain is off. The photo is misleading, but the chain is off both sprockets in that photo. Actually just in front of the sprocket.
I want a lower first gear, and a lower 6th. 6th gear is basically useless for me. And I'm thinking about the 4th gear wheelies I'll be able to do.
Dropping the front back down at 80 MPH
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-07-2014, 02:05 PM   #10
Black Hills
Oddometer: 1,323
I was wanting the same, but found the 16 front to make it feel like it just revs but doesn't really pull? if that makes any sense? anyway good luck!
Old 05-07-2014, 02:08 PM   #11
Black Hills
Oddometer: 1,323
oh, yea it took every cuss word I know and a few I just made up before it finally came off
Old 05-07-2014, 05:34 PM   #12
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
I didn't wait long before getting the Dremel. It was not coming off without some modification. I just took the two teeth down a little. Kept doing that until it came off. The sprocket is still usable if I ever want to go back.
Will find out tomorrow and this weekend how much I like it with a 16.
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-07-2014, 05:46 PM   #13
brooks
Oddometer: 332
If you ever do it again make sure the lock washer tab has been bent away from the nut,leave the chain on, use the rear brake to keep the rear wheel from spinning. Break the nut loose and take it off. a little wd 40 and a couple taps from a rubber mallet will loosen the sprocket. move the rear wheel forward and take the chain off the old sprocket and put on the new. Boom
Brooks
brooks is offline   Reply With Quote
Old 05-07-2014, 05:54 PM   #14
mlyamkaw OP
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 572
No, that is not how it works on this bike! That was the 5 minute part of the job, and that was with a beer break.
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-08-2014, 04:40 PM   #15
JoeShoreline
Oddometer: 59
I think they used locktite on the splines. Use a puller, or 2 small curved pry bars( with 90 degree bend) from behind and gently rock it back and forth until it starts to move.
JoeShoreline is offline   Reply With Quote
Times are GMT -7.   It's 10:33 AM.
