Old 07-17-2014, 11:06 AM   #211
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,360
Originally Posted by c-zulu View Post
Guzzi Stelvio..
Originally Posted by sanjoh View Post
Nice bike! Have you tried adjusting the headlights?
He tried, but she slapped him silly!
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 07-17-2014, 02:44 PM   #212
c-zulu
Resident Dirt Burner
c-zulu's Avatar
Oddometer: 1,404
Nice bike! Have you tried adjusting the headlights?]
Not yet, will do 2nite.
c-zulu is offline   Reply With Quote
Old 07-18-2014, 03:50 AM   #213
HPTuner
Oddometer: 347
Hey Sanjoh, any replacements for an H9?
HPTuner is offline   Reply With Quote
Old 07-18-2014, 06:17 PM   #214
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Any plans for an H1 LED?
spartanman is offline   Reply With Quote
Old 07-19-2014, 11:42 AM   #215
Molonlabemike
Molonlabemike's Avatar
Oddometer: 406
Just placed my order...forgot to put my unit number
Hopefully you guys got my email to add it I'm a dumbass sometimes
Molonlabemike is offline   Reply With Quote
Old 07-20-2014, 09:41 AM   #216
K7TNT
K7TNT's Avatar
Oddometer: 343
H7s
Ride Safe, Richard 14 F700GS IBA #59670, MOA #114372 ( My Wyoming has an East infection )
K7TNT is offline   Reply With Quote
Old 07-21-2014, 04:56 AM   #217
zeeede
Oddometer: 1,139
During the process of wiring up some ADVmonster model 30's, over the weekend, I noticed that the low beam on my fiancee's '09 G650GS is burned out. Just ordered an H4 for her. I'll report back on fitment after it's received.
zeeede is offline   Reply With Quote
Old 07-21-2014, 10:19 AM   #218
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,288
I've put one in a Dakar, tight fit, worked wonderfully without the shield.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 07-21-2014, 12:28 PM   #219
zeeede
Oddometer: 1,139
Thanks for the heads-up. Any dis-assembly required, or were you able to squeeze it in by reaching down between the bars and the fairing?
If I can't get it to fit on her bike, I'll order a second one and put 'em both on my Vstrom
Old 07-21-2014, 12:31 PM   #220
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,288
No disassembly required. If you have large hands, you might want to recruit a helper.
sanjoh screwed with this post 07-21-2014 at 12:37 PM
Old 07-21-2014, 08:04 PM   #221
argentcorvid
Some Guy
Oddometer: 505
progress on my Uly with H7's is slow, but happening. I'm making a new sub-harness. I have the connector and pins, just need to triple-splice the grounds together; the sub harness has 4 pins, 3 for power and one for ground.
I used some EPDM/neoprene pipe insulation trimmed up to fit the gap left by not being able to use the boots.
argentcorvid is offline   Reply With Quote
Old 07-24-2014, 05:50 PM   #222
argentcorvid
Some Guy
Oddometer: 505
Well I ran into a snag.
I have everything wired up, and was doing a test fit, making sure the lights worked. The high beam didn't turn on.
I checked that voltage was present, and that was good, so I disconnected the connector on the light and found this:
That pin is definitely broken off. Not sure why I didn't notice that when I plugged it in.
Old 07-25-2014, 01:58 PM   #223
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,288
Send me an email (sandjoh@gmail.com) will get you a replacement.
Old 07-28-2014, 06:48 AM   #224
zeeede
Oddometer: 1,139
Install went fine on the '09 G650GS. I was able to install without disassembling any of the fairing using my giant hands.
Her old headlight was burnt out, so no before/after pictures. Next time her bike is out at night I'll try and get an after picture, just for kicks.
A much whiter, more visible light. I like that the white light of the headlight LED matches the white of her Model 30's ADVmonster aux lighting.
Old 07-28-2014, 11:15 AM   #225
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,288
Thanks for the update. No more yellow halogen
Here's a Wr250R with Model 60s and our H4 LED Headlight. Looks like a match
Times are GMT -7.   It's 01:24 PM.
