Old 05-21-2014, 08:45 AM   #46
mtncrawler
mtncrawler's Avatar
Oddometer: 1,133
Originally Posted by sanjoh View Post
The small bulb is a "parking lamp" . It is not used while underway.
The H4 led headlight has a high and low beam.
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Old 05-21-2014, 10:13 AM   #47
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,274
H7 LED Headlight Volunteers Found
Thanks for the interest.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 05-21-2014, 09:49 PM   #48
c-zulu
Resident Dirt Burner
c-zulu's Avatar
Oddometer: 1,403
What is the measurement between the 3 pointed star flange and the heat sink?
The reason I ask is that not all H4 use the wire retainer but instead use a plastic locking ring.
c-zulu is offline   Reply With Quote
Old 05-22-2014, 06:40 AM   #49
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,200
Originally Posted by robsmoto View Post
I have a /5 as well as a GS like Sanjoh used for his first test install of the H4 bulb. Using the MaxBMW on-line parts fiche,the bulb for the R100GS is shown as an H4 bulb (part # 63 12 1 354 619 for $15.26). The /5 headlamp diagram shows a different appearing bulb (not H4 type) and has a different part number (07 11 9 978 396 for $9.47). Thus, it appears that the /5 may not be quite as simple a bulb swap out as for the /6, /7, and later airheads.
https://www.maxbmwmotorcycles.com/fi...5&rnd=04282014
The non-halogen bulb (P3???) in the /5 is not directly interchangable with an H4 bulb. The lamp flange and bulb position (focus) are very different.
One solution would be to get an H4 headlamp conversion made for the /5. Plastic lens (nothing wrong with that, they're all plastic for the past few years) with an H4 bulb, it is a bolt-in conversion. Sell the H4 bulb, plug in the LED bulb and you're in business. The LED heatsink protrudes behind the reflector, but I _don't_think_ that will be a problem, though you may want to reroute some of the wiring around the heatsink.
Cost is about $120 from Hucky (Hans Lowe), which is not terribly terrible.
http://bmwhucky.com/007563.html
'73 R60/5 Toaster
Old 05-23-2014, 03:18 AM   #50
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,274
14mm from flange to front of heat sink
37mm from flange to back of heat sink
49mm from flange to back of unit
Old 05-23-2014, 01:13 PM   #51
Hack'dTiger
n00b schn00b
Hack'dTiger's Avatar
Oddometer: 830
1. David - 12' Super Tenere
'12 Super Tenere | '07 KLR | '07 KLX250S | '06 Road Star w/Ural Sidecar | '02 Road Star Bobber | '02 YZ426F | '75 CB750
Hack'dTiger is offline   Reply With Quote
Old 05-24-2014, 03:18 AM   #52
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,274
Color Temperature
08' Yamaha WR250R, H4 LED Headlilght (low beam), 2x Model 60s (5500k color temp) dimmed.
Old 05-24-2014, 09:17 AM   #53
c-zulu
c-zulu's Avatar
Oddometer: 1,403
Has anyone tried fitting the H4 into a KTM SE Headlight bucket?
Old 05-25-2014, 11:38 PM   #54
tc339
tc339's Avatar
Oddometer: 61
Would love to here if anyone ends up trying these on a Tenere.
tc339 is offline   Reply With Quote
Old 05-26-2014, 10:35 AM   #55
c-zulu
c-zulu's Avatar
Oddometer: 1,403
Giving this H4 a try, fingers crossed..
Old 05-30-2014, 03:46 AM   #56
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,274
Lights are in!
Will begin shipping on Monday.
The response to the H4 led headlight at the BMW RA rally has been staggering. Many bikes fitted and there hasn't been a bike that the H4 led did not fit.
Everyone was impressed at the light show last night.
Old 05-30-2014, 09:01 AM   #57
tyrsmkkyle
off the ground.
Oddometer: 250
any 14 690 r's get one fitted? Im thinking about getting one of these aswell, It would compliment my m60s nicely.
tyrsmkkyle is offline   Reply With Quote
Old 05-30-2014, 01:13 PM   #58
ModMan
Random Adventurer
Oddometer: 39
Such a shame, I'd kill for one of these on my BMW X Country (H4) but the way the back of the headlight is moulded it doesn't look like this'll fit. Unless anyone has managed to do it?
ModMan is offline   Reply With Quote
Old 05-31-2014, 03:52 AM   #59
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,274
Did a halogen vs led comparo on a Vstrom that uses 2 H4. Everyone was shocked at the improvement in output. Owner couldn't get his money out fast enough!
Old 05-31-2014, 07:44 AM   #60
Texcollect
Adventurer wannabe
Texcollect's Avatar
Oddometer: 200
You know the rules.... Without pictures it didn't happen
If you love your bike, set it free. If it comes back to you, you just highsided.
Texcollect is offline   Reply With Quote
Times are GMT -7.   It's 04:34 AM.
