Old 05-09-2014, 09:17 AM   #1
p-luc OP
Let play out-side
Oddometer: 24
Lc8 with too much oil?
Adv 990 with too much oil, is it a big issue or not? When I did my oil change I put too much.
p-luc is offline   Reply With Quote
Old 05-09-2014, 09:22 AM   #2
renogeorge
Oddometer: 1,365
Both my 950 and 990 would push oil out the breather if overfilled. Easy enough to suck out excess through filler cap
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 05-09-2014, 05:13 PM   #3
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 402
Yes you can damage the engine by overfilling, best drain some oil out.
2014 KTM 1190 Adventure R
Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 05-09-2014, 05:15 PM   #4
p-luc OP
Let play out-side
Oddometer: 24
Will do, thanks guys
Old 05-09-2014, 05:35 PM   #5
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,742
Your only overfilling the oil tank - it's a dry sump motor.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 05-09-2014, 06:13 PM   #6
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 734
+1 Yep it will make a mess if it overflows the tank but won't hurt anything.
The only caveat is that if the check valve is bad on the bottom of the tank it will fill up the crankcase, I haven't tried to see how much volume the LC8 case has in it.. I check my oil before I start riding for the day/week, so if the check valve was bad the tank would be empty.. But the scavenger section of the oil pump will empty the motor back to the tank in about 2 seconds..
http://www.dansmc.com/4_stroke_oilpump.htm <- Nice little writeup on bike oiling systems if you've never looked at a dry sump it clears up how they work.
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 05-27-2014, 06:34 AM   #7
Bowser
Oddometer: 165
no you cant
Bowser is online now   Reply With Quote
Old 05-27-2014, 06:47 AM   #8
ADVill
Oddometer: 608
Originally Posted by Bowser View Post
no you cant
Overfill your's :)
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 05-27-2014, 11:43 AM   #9
Hill Climber
Oddometer: 347
Yeah, this is an important topic. I recently bought a 990, and before riding I always check the oil level. It's been at the half way mark on the stick. After reading the owners manual, it states that one should check the oil after the engine is warm....? WTF? So I did, and the the oil level was at the top mark on the stick. I need to understand how this can be..... It'd be really easy to overfill the reservoir, by filling to the top mark with a cold motor.
08 ktm530
12 ktm990Adventure
Hill Climber is offline   Reply With Quote
Old 05-28-2014, 02:38 AM   #10
ericGSsti
ericGSsti's Avatar
Oddometer: 540
I look at it as don't top it up or check it when the motor is cold. The manual states do this when it's warm so stick to the manual and you Cann't go wrong
wrong. If you over fill it why tare a chance on wheater it can cause damage or not. Drain it to the correct level.
Lads have different opinions about it as you can see above but who's right. I wouldn't be taking a chance.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 05-28-2014, 05:24 AM   #11
Spayn
Oddometer: 84
FWIW
FYI 1190 will do the same...
Spayn is offline   Reply With Quote
Old 05-28-2014, 06:50 AM   #12
ADVill
Oddometer: 608
520 will do the same but I don't make it do it :)
'00 520 EXC
'14 500 XCW
Times are GMT -7.   It's 02:18 AM.
