Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-13-2014, 01:23 PM   #1
keener OP
Speed changes you.
keener's Avatar
Oddometer: 981
How to bleed coolant on 1190 RC8 engine
We flushed the coolant on my friend's RC8 a week ago. It has the same engine as 1190 ADv of course. We followed the manual. Raised the front 50cm, opened bleeding screws and filled up the coolant then lower the front and fill up the expansion tank.
The trouble is, bike keeps losing coolant when its hot through the expansion tank's drain hose. When it gets cold, coolant level goes bellow min. I repeated the bleeding process again yesterday, but nothing changed.
Is this because there is still air in the system?
I'm not sure what else we can do to remove the air. No bulbs coming out of the bleeding holes.
On my 950, I don't even raise the front (even as it suggests on the manul). I just squeezes the 1" hoses several times and that does it. What's the trick with RC8?
thx
04 ADV 950
keener is offline   Reply With Quote
Old 05-18-2014, 01:21 AM   #2
Wissam
Wissam's Avatar
Oddometer: 17
thx
I have the same problem. I could not bleed the system. Have you found a solution
Wissam is offline   Reply With Quote
Old 05-19-2014, 04:21 AM   #3
keener OP
Speed changes you.
keener's Avatar
Oddometer: 981
kinda!
I raised the front and removed the radiator cap. Then ran the engine and kept adding coolant as the level went down. Also I squeezed the hoses many times.
Becarefull when you squeeze the hoses as it pushes the coolant into the rad so it may overflow if the level is high. Level can come up by itself too. You can hold something close the radiators mouth to capture most of it.
Then I waited until fan kicked in around 94C and thermostat opened. Level when down,I pumped the hoses then added coolant.
This got rid of most of the air. Now when bike cools down, coolant level goes back to almost where it was. It overflowed a bit during a ride afterwards but it was much less than before doing the no rad cap method.
I think I should repeat this process one more time.
good luck
04 ADV 950
Old 05-19-2014, 06:53 AM   #4
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
Radiator cap?
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-19-2014, 09:21 AM   #5
fast4d
Oddometer: 2,452
yeah, there is a radiator CAP on the RC8
I'll change my coolant in the coming weeks as it is overdue.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 05-19-2014, 09:59 AM   #6
Alleycatdad
Oddometer: 1,440
No. Is your rad cap good? My 990 behaved exactly like you describe when the cap went bad.
Old 05-22-2014, 02:44 AM   #7
keener OP
Speed changes you.
keener's Avatar
Oddometer: 981
may be. I replaced my 950 cap too. as preventative maintenance because I knew it will fail.
04 ADV 950
keener screwed with this post 05-27-2014 at 06:10 AM
Old 05-27-2014, 06:10 AM   #8
keener OP
Speed changes you.
keener's Avatar
Oddometer: 981
I though I make an update, because I finally managed to bleed the RC8 cooling system.
There was nothing wrong with the cap.
I raised the front 50cm then ran the engine and took the radiator cap of every now and then to check if coolant level had gone down. Topped it of as needed.
I waited until fan came on so I am sure thermostat is open. I shut the engine and opened the bleeding screws on the engine. Lots of air came out. More from the front cylinder.
I ran the engine again until fan came on and repeated this process about 4 or 5 times.
Every time I bled the system I topped of the radiator. Note make sure bike is on level ground from side to side so u don't have to open the bleeder screw on the top of the rad.
When the fan comes on wait a few seconds before killing the engine so coolant gets a chance to circulate .
I lowered the bike and added coolant to expansion tank as needed.
On my LC8 950 to know if system is air free, I mark the coolant level on the expansion tank when COLD, then I go for a ride to warm up the engine very well. Then I let it cool down for couple hours and check the coolant level on the tank. If it is not significantly higher or lower I know there is no air in there. I did the same for the RC8.
04 ADV 950
Old 03-26-2015, 03:44 AM   #9
mcguyver
mcguyver's Avatar
Oddometer: 1,288
Keener
Could you please tell me which are the bleeder screws on he head.
mcguyver is offline   Reply With Quote
Old 03-26-2015, 03:48 AM   #10
Katoom72
Katoom72's Avatar
Oddometer: 910
Originally Posted by mcguyver View Post
Keener
Page 196, 5th picture
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Times are GMT -7.   It's 05:29 PM.
