Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-16-2014, 06:23 PM   #1
PBrad OP
Oddometer: 157
Help, need rear tire for 1190r in DC area
I trashed the stock conti trailattacks on a sharp rock while on the TET today. Tire plug isn't holding. Anyone in the DC area have a set of tires that I could buy to use to get back up to boston? The Ktm dealer in the area doesn't have anything in stock....
PBrad is offline   Reply With Quote
Old 05-16-2014, 07:12 PM   #2
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 545
You could always tube it if the carcass is still smoothe on the inside. The offset valve shouldn't be a problem, others are doing it, and I have done it on a GSA withe the offset valve.
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
mlyamkaw is offline   Reply With Quote
Old 05-16-2014, 10:15 PM   #3
sonoran
you already know
sonoran's Avatar
Oddometer: 24,258
Might want to post in regionals to get visibility.
Good luck!
sonoran is online now   Reply With Quote
Old 05-17-2014, 08:18 AM   #4
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 395
i have a set clear across the country with 600 mi on them HW
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 05-17-2014, 01:40 PM   #5
PBrad OP
Oddometer: 157
I was able to find a tube at a dealer. Works great!
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 05-21-2014, 11:58 AM   #6
PBrad OP
Oddometer: 157
Not sure what happened here, but I was running stock tire pressures. It looks like the tire just cracked and split. I plugged the area what first started to leak, which worked for around 100 miles, I then put a tube in it. Its also now warped, causing the bike to ride funny. Its cominbg out as soon as the dealer gets a replacement for it. I do like the tire otherwise. Its pretty good tire in most everything as long as you stay far away from mud. Sand is a bit tricky too, but not too bad if you relax and slow down a bit. For me, besides getting damaged, its a perfect fit. Lets hope the 2nd one holds up better.
Old 05-21-2014, 12:28 PM   #7
mlyamkaw
Drill Baby Drill
mlyamkaw's Avatar
Oddometer: 545
I see other spots the carcass is cracking. Does it look like that as you rotate the tire to other spots?
I wouldn't ride it like that, and it may be a warranty issue for the tire Mfg?
14 KTM 1190R
09 KTM 300 XC-W
13 Ural Gear Up
14 KTM 500 EXC
Old 05-21-2014, 02:00 PM   #8
PBrad OP
Oddometer: 157
You'd think they'd warranty it? I didn't even think these tires carried a warranty. It's cracked like that in 3 places. I've parked her until I get a new one installed.
Old 06-15-2014, 03:01 PM   #9
PBrad OP
Oddometer: 157
Ktm replaced the tire under warranty for me. :)
Times are GMT -7.   It's 12:30 PM.
