Old 05-16-2014, 09:06 PM   #1
skandero OP
skandero's Avatar
Oddometer: 121
Master cylinder leak - any way to solve temporary?
Hello.
My friend's 990 got a leak from the clutch master cylinder. Not so bad, but annoying. He ordered the rebuild kit...
But is there any way to solve this issue temporary, before the kit arrives? Can the leaking cylinder fail totally, if it will be disassembled and reassembled again, or reassembling can give a chance to stop leaking?
Is there any temporary solution?
MotoCraft Racing Team, Russia.
KTM 950 Adv '04
You got to love the Lynx...
skandero is offline   Reply With Quote
Old 05-16-2014, 09:40 PM   #2
renogeorge
Oddometer: 1,364
It is very unlikely that it would fail completely if you can keep fluid in it and don't allow the level to drop so low that air is drawn into the line. You might get lucky and find a seal that would work. As I recall the seals are washer style--not O rings.
Good luck
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 05-17-2014, 05:16 AM   #3
charlie264
charlie264's Avatar
Oddometer: 8,263
put thicker oil in until the seal kit arrives.....
Old 05-17-2014, 09:07 AM   #4
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,830
Take it apart. Clean it and put it back together again.
DELTATANGO is offline   Reply With Quote
Old 05-17-2014, 03:17 PM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
I think they usually have no hope.
The cylinder gets worn and eats into the washer. Replacing the washer and piston, could work for a month at most. Then things take their toll. The best fixture IMHO is replacing or resleeving the cylinder.
Temporary fix could be using thicker oil as charlie264 suggests, but in heavy traffic you could be struggling with your clutch lever, especially in low temps.
Cheers.
Old 05-18-2014, 12:20 AM   #6
skandero OP
skandero's Avatar
Oddometer: 121
Thanks for the answers. We decided to wait for parts and rebuild, it is not too hard to add some oil one-two times, while waiting the parts. The leak is not so bad, and I think there is a risk of getting bad leakage in case of cleaning an old cyl and piston...
KTM 950 Adv '04
skandero screwed with this post 05-29-2014 at 09:28 PM
Old 05-18-2014, 06:07 AM   #7
Martynho
No more Chilegringo.
Oddometer: 408
Different continent, same situation
Hi mine looks to be in the same condition. I have been keeping on top of the oil level for a month now awaiting parts here in Chile with no issues (only a slight weep of fluid). The best solution I have seen is to use a master cyl from an EXC. You lose the daft clutch switch but gain by taking out the mirror mount on the master cyl (relocate using a recycled BMW item)
Martynho is offline   Reply With Quote
Old 06-17-2014, 11:31 PM   #8
skandero OP
skandero's Avatar
Oddometer: 121
So, looks like gefr was right: we replaced the piston and things were good... for two weeks) Then the leak appears again.
What replacement ideas do you have, guys? EXC cyl as Martynho said? Radial cyl? Any aftermarket kits? Found http://www.advrider.com/forums/showthread.php?t=655984, but still looking for new ideas)
KTM 950 Adv '04
skandero screwed with this post 06-17-2014 at 11:56 PM
Old 06-18-2014, 12:02 AM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,917
I do a resleeving job, droping also the diameter to 9.0 or 9.5mmmm
It needs to get to me though. It is not temporary and it is not fast. Cheers.
Old 06-19-2014, 11:33 PM   #10
Szepy
Szepy's Avatar
Oddometer: 24
Just one trick (wondering why KTM dealers don't do it everywhere) change clutch oil at every service. I had the same problem with my 950, my friends also had it with the 990. With regular clutch oil change my 990 has 76000km in it and no clutch leaking.
I suppose this clutch was designed for excs (light and very small) but Adventures run lot more hours before complete rebuilding than EXCs. :)
BTW if it just started to leak it'll take a few weeks (thousands of km) until they give it up. Just fill them up regularly!
2006 KTM LC8 990 Adventure (still rocks but I miss the 950 much)
2003 KTM LC8 950 Adventure (stolen... )
2001 KTM LC4 640 Adventure (sold)
1990 Honda Dominator - (sold)
Szepy is offline   Reply With Quote
Times are GMT -7.   It's 06:23 AM.
