Old 05-17-2014, 01:27 PM   #1
tomdubz OP
getting there
tomdubz's Avatar
Oddometer: 517
Battery or VR?
Left the light on and killed the battery.
Tried jumping from truck. Did as done before: leave truck off. Wait 5 min or so while everything is hooked up. Fire bike up. Turned over a few times but not enough umph.
So, I turned bike off started truck and turned bike on. Fired up fine. Took cables away and within 1 minute the bike dies.
Scratched head. Attached cables again letting the truck run for a little while connected, bike off. After about 3 minutes fired bike up and let it stay cabled for a minute or so. This time, once taking cable away bike died immediately.
So, 5 year old battery finally dead or is something else brewing? Using remote positive terminal and foot peg off bike if that matters... Shouldn't right?
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 05-17-2014, 02:23 PM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,006
5 years old battery died after draining it completely.
An electrician could check it out for you but since the motor dies that fast, the battery cannot hold charge and could have some cells shorted.
Cheers.
Old 05-17-2014, 02:30 PM   #3
tomdubz OP
getting there
tomdubz's Avatar
Oddometer: 517
Cheers.
That's what I figured. Thanks for the reinforcement.
Old 05-17-2014, 06:46 PM   #4
renogeorge
Oddometer: 1,395
I'd be checking connections at the battery. You could put a charger on the battery and see if it takes a charge. At 5 years, you got your money's worth out of that battery. Regulator can be checked with volt meter with bike running.
Foot peg is not a very good ground connection....
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 05-20-2014, 12:00 PM   #5
tomdubz OP
getting there
tomdubz's Avatar
Oddometer: 517
FWIW
Because it's not connected to the frame?
Has always worked for me in the past.
Thanks for the other suggestions.
Times are GMT -7.   It's 01:10 PM.
