Old 05-18-2014, 03:09 PM   #1
keener OP
Speed changes you.
keener's Avatar
Oddometer: 983
Holes on rear break pistons
This is a photo if rear break caliper of my 04 950 adv.
I have never seen anything like this.
There is no leak, break works fine.. Is this going to cause any issue?Name:  uploadfromtaptalk1400450900570.jpg
04 ADV 950
keener is offline   Reply With Quote
Old 05-18-2014, 03:59 PM   #2
charlie264
charlie264's Avatar
Oddometer: 8,368
Just covers over the piston...some brakes just don't use um...not leaking fluid I wouldn't worry
Old 05-18-2014, 04:57 PM   #3
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,071
No problem
Has no specific use but to cover the "tube"-piston opening.
Cheers
Old 05-19-2014, 04:09 AM   #4
keener OP
Speed changes you.
keener's Avatar
Oddometer: 983
thx guys, I put a bit of caliper grease and buttoned it up.
I rode in a ton of muddy trails in the last couple of week.
Sent from my LG-D803 using Tapatalk
04 ADV 950
Old 05-19-2014, 06:20 AM   #5
spafxer
spafxer's Avatar
Oddometer: 2,647
Cheers
They do help prevent heat transfer into the brake fluid....
spafxer is offline   Reply With Quote
Old 05-19-2014, 06:43 AM   #6
Bowber
Oddometer: 184
I think their main use is to stop the piston filling with dirt and water and they also help insulate the piston from the pad heat.
Steve
Bowber is offline   Reply With Quote
Old 05-19-2014, 07:47 AM   #7
keener OP
Speed changes you.
keener's Avatar
Oddometer: 983
thank you.
whats the best practice to prevent this? grease will be washed off quickly.
04 ADV 950
Old 05-19-2014, 11:41 AM   #8
ADVill
Oddometer: 609
JB Weld and sand it flush?
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 05-19-2014, 03:34 PM   #9
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 733
Looks like water got in behind them and started corroding the faces from the inside-out.(?)
HeatXfer is offline   Reply With Quote
Old 05-19-2014, 05:26 PM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,071
What you see on the photo with the hole is plastic.
It corroded.
Cheers.
Old 05-22-2014, 02:42 AM   #11
keener OP
Speed changes you.
keener's Avatar
Oddometer: 983
it didn't look like the caps are steal. They seem to be some kind of plastic.
I think the vibration of pads sanded the ends in combination with sand from mud. Pads were worn 100%. So much that one fell off from one end by itself. They were just not the right pads for mud.
The springs are supposed to prevent this I guess ,but not when pads wear that much?!
new kind of pads are in and there is no play.
04 ADV 950
Times are GMT -7.   It's 09:28 PM.
