Old 05-19-2014, 12:48 PM   #1
brian777 OP
We're there!
Oddometer: 10
Garmin 62 stc
Hello!
Looking for pros and cons of the Garmin 62 stc for dual sport riding. Looking for feedback on this unit.
Thaniks!
Brian
brian777 is offline   Reply With Quote
Old 05-19-2014, 01:43 PM   #2
mcnut
Oddometer: 1,375
Originally Posted by brian777 View Post
Hello!
Thaniks!
Brian
Get the 78 instead of the 62 as they are virtually the same function/spec, but the 78 has a much better power plug option for hard wiring.
Why do many skip past the 78 if it is the preferred choice? It is only listed in Garmin's "On the Water" line, the 78 has the buttons on top (Better IMO) which is counter to what people are used to and finally the 62 seems the logical successor to the wildly popular 60 but the 60 had the good connector the 62 doesn't.
Garmin 78, the best way to go if you like buttons!
Bruce
mcnut screwed with this post 05-20-2014 at 11:29 AM
mcnut is offline   Reply With Quote
Old 05-19-2014, 09:39 PM   #3
Countdown
Oddometer: 5,629
Bruce
$150 at WestMarine.com
Jerry Counts
Countdown is offline   Reply With Quote
Old 05-19-2014, 10:14 PM   #4
Molonlabemike
Oddometer: 300
Just picked a 62stc from REI for $249, this being my first handheld GPS I think its going to be big asset to my gear. Given its only battery powered, AA are cheap and I can purchase additional rechargeable batteries to keep it going.
Now back in my GPS noob hole
Molonlabemike is offline   Reply With Quote
Old 05-19-2014, 10:28 PM   #5
Countdown
Oddometer: 5,629
Originally Posted by Molonlabemike View Post
Just picked a 62stc from REI for $249, Given its only battery powered, AA are cheap and I can purchase additional rechargeable batteries to keep it going.
Vibration is enemy of GPS, always use the light weight AAs which are not cheap, $5 every other day. Power from motorcycle is free, batteries then last almost forever.
Jerry Counts
Old 05-20-2014, 03:17 PM   #6
justdirtyfun
justdirtyfun's Avatar
Oddometer: 333
I use the same model and will be trying my AC power cord with a small inverter. Maybe. Someday. Possibly.
Does it sound doable? I have some regretts on this model but will live and learn.
justdirtyfun is offline   Reply With Quote
Old 05-20-2014, 07:29 PM   #7
Countdown
Oddometer: 5,629
Originally Posted by justdirtyfun View Post
I use the same model and will be trying my AC power cord with a small inverter. Does it sound doable? .
Are you really serious? The question is; is it safe? I guess if the inverter has a "ground fault" protection circuit that trips on 5 mA differential between black & white wire, it can't kill you but I wouldn't trust it.
A much safer option is a 12V to 5V (USB) power converter. Only danger is if it fails shorted, it toasts the GPS.
Jerry Counts
Old 05-21-2014, 06:20 AM   #8
justdirtyfun
Oddometer: 333
This stuff should be simple but its not. For example, when connected to a pc the connection will only tranfer data but using the ac cord it allows gps function and bypasses the batteries.
Because of this I assumed a 12 to 5 volt input might act like a pc connection and try to transfer data. Somewhere in the usb connector must be a signal wire to differentiate between the two connections.
This hopefully makes some sense to a few people. Any thoughts?
Old 05-21-2014, 06:50 AM   #9
he man
Oddometer: 60
I believe there are special USB cables that only trigger the power function instead of the Computer connection function.
he man is offline   Reply With Quote
Old 05-27-2014, 11:39 AM   #10
brian777 OP
We're there!
Oddometer: 10
thanks for the tips!
I was going to buy the REI deal but having power is a real plus!
Old 05-27-2014, 09:19 PM   #11
Countdown
Oddometer: 5,629
Very few if any.
Jerry Counts
Old 06-06-2014, 02:11 PM   #12
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 427
As long as there's a thread going....
Is the screen on the 62 large enough to make it usable while moving? I'd really like to get a track-enabled GPS and the 62stc keeps going on sale making it awfully tempting.
I like the buttons vs. touch screen & it seems to do everything I'd want. That screen reminds me of digital cameras from 2005 though.
Thanks,
Jeff
FriedDuck is offline   Reply With Quote
Old 06-06-2014, 02:38 PM   #13
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,735
The 78sc is on sale right now for $199 at West Marine (no camera or topo map). The screen and functions of the 78 are otherwise the same as the 62, but the 78 has the 12v power connector that makes it a superior choice for motos (no 12v connector on the 62). The screen size on the 62 and 78 is too small to read text and details while riding, but if you're following a track, you can see the track line fine.
New desert racing frontiers
It will be Devilish !
HogWild is online now   Reply With Quote
Old 06-06-2014, 07:01 PM   #14
mcnut
Oddometer: 1,375
If you are honest with yourself about your 2-3 ft eyesight! If you need help with menus in restaurants you don't qualify.
Bruce
HTML code is Off
Times are GMT -7.   It's 06:30 AM.
