Old 05-20-2014, 08:03 AM   #1
Jbone11 11 OP
Jbone11 11's Avatar
Oddometer: 739
Are there no Cheaper options?: HID KTM 990adv
Like many 950/990 owners before me, I have recently become a little concerned over the ability of my US spec headlight to cast enough light at night. For me this is mainly due to two factors: 1- I am doing more rallies that have me riding through the back of beyond at night and 2- after getting PRK surgery on my eyes my nightvision is not what it used to be...actually it just takes much longer for my eyes to adjust, but its a PITA and better lighting at night would be hugely beneficial.
Anywas, I've researched the Euro spec options as well as some really nice custom jobs (Britania Composites "VooDoo" rig is very nice...but $$$. Worth it, but not in the budget this year.
But I have found little to no info on simply swapping the stock bulbs with HID's....is there a specific reason for this? A buddy of mine who is a KLR rider and pretty savy with electrics, bought a 35$ HID kit from ebay and has put well over 13k on it....comes with a dedicated ballast for the HID system and requires some basic alterations, but the result is pretty amazing from stock. Coupled with a set of LED's for less than $100 mounted to the crash bars and I've got a lighting set up better than the Euro spec for less than $200 CAN.
So, the question: Is/has anyone looked nto this "cheaper" option?
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 05-20-2014, 08:23 AM   #2
EZ300
EZ300's Avatar
Oddometer: 1,116
Here's an option:
Run aux lights.
Stock light
Mondomotos lights
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 05-20-2014, 08:23 AM   #3
jconly
jconly's Avatar
Oddometer: 409
Currently running the Euro headlight, with a DDM HID in the low beam.
The Euro headlight casts a different beam pattern than the US.
I've been using DDM's HID's in my bikes for years now, and have always been more than happy. Light output with my current setup is great for riding down the road in the dark.
For a brief while, I was also running an HID in the high beam, but pulled it. Problem with this setup is the few seconds it takes to kick in. Not good when you need to flick the light on and off, or flash your beams. Running a PIAA bulb in the high instead, and honestly, it doesn't do much when paired with the HID in the low.
I do still plan to add some AUX LED's to the bike as well, for riding down those dark trails. There are definitively times I want it.
Also curious about these new LED headlight bulbs that are now starting to pop up. Could be a great new option, especially for that high beam.
jconly is offline   Reply With Quote
Old 05-20-2014, 08:30 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
I have Euro bike.
Have installed HIDs and am very happy. However a friend installed lately a led lighting bar
http://www.ebay.com/itm/40W-8inch-Cr...item3a9082bbb5
and is incredible!
Cheers.
Old 05-20-2014, 08:45 AM   #5
Jbone11 11 OP
Jbone11 11's Avatar
Oddometer: 739
Yes sir....Aux LED's are on the menu for sure! I've also seen other KTM's with the LED bar. Was thinking of a way to mount aux lights to the forks however so I have some steerable light....nice to be able to see that Deer standing in the middle of the road before the rest of me gets there ....EDIT: just realized those mondomotos Aux's were mounted to the triples....that come with or a custom job?
I think I've narrowed the search down a bit...I found a possible kit at vvme.com....and for less than $40, what the hell....if it dosen't pan out...its only $40....But if it does....its only $40!
Gonna order early next weekish I think...I'll update with the results.
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
Old 05-20-2014, 10:55 AM   #6
Mikef5000
Oddometer: 2,030
There are a few reasons you don't see HID bulbs on the KTMs all that often.
1) HID bulbs in a non-projector housing don't work anywhere near as well as they could. Instead of having focussed light with a cutoff like this:
You'll be left with scattered and unfocussed light, that is blinding to oncoming traffic (and illegal, if that matters). More like this:
2) The KTM uses a single High/Low bulb. In order to make that work with a single HID arc, they have to use a small shield and magnet, and the bulb itself moves in and out to show more light or less. Usually something like this:
So now you've got moving parts (the bulb has to slide freely) susceptible to breaking or malfunction, and big shields blocking the light output. Your 3200 claimed lumen bulb already has drastically less light output because of the less-than-ideal housing/reflector, and now is ~75% blocked on low beam, and ~25% blocked on high beam.
They're just not worth it in my opinion. (That being said, I've used VVME several times in the past, and would recommend their non-bi-xenon kits.)
The Euro spec housing eliminates the high/low beam single bulb issue, so, even though the light output is still not focused well, at least it doesn't have the moving parts and metal shielding.
Like mentioned earlier, I think the best option, by far, is the LED axillary light setup. If you're looking for a deal, ebay is an awesome source. I can't comment on quality, although I've been impressed with what I've seen. I love the new Combo Light Bars that are flooding the market; flood lights on the ends, and spot lights in the middle. There are several between $55 and $85:
If you still find the need for steerable light, you could add a couple tiny 10w LEDs to your handlebars starting at about $35 a pair.
(Of course, we have a vendors section here with numerous options as well... I just threw out ebay because... well.. this whole thread is about cheaper options. Supporting our vendors = good)
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 05-20-2014, 12:02 PM   #7
Jbone11 11 OP
Jbone11 11's Avatar
Oddometer: 739
Very interesting...thanks for that write up mike, definitely food for thought. After having a quick chat with my buddy I think what Im going to do is get a white halogen and stick that in there for now and research the HID's a bit more. We basically discussed the same issue you brought up about the un-focused light, albeit, not in such a succinct way.
I really want the Britania Composites mod as it not only looks great IMHO, but the lighting upgrade is there as well. They've combined a 60mm HID projector low beam lamp and a Baja designs Squadron LED Hi Beam...supposedly a huge improvement over stock US or EU spec.
But at $800, its a hit to the wallet for sure and not doable by mid June which is when I need to have the lighting thing sorted.
So its cheapo-central for now....I'll be checking into vvme a bit more but I'll also be looking at some LED AUX lights as well. My klr buddy has a set he bought but they have yet to be truely tested....that will change this weekend on the Roaming Rally however
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
Old 05-20-2014, 12:43 PM   #8
catalina38
Contrarian
Oddometer: 1,645
I have the Euro headlight on my 990R and had the DDM tuning 55w HID lights for a couple of years with out any problems other than fitting the ballasts in behind the headlight. They put out a lot of light but not where I wanted it, a lot of it went too high and would light up trees and far away signs but not enough on the road. I went back to halogen bulbs and separate LED lights. I have the Baja Designs Squadrons and even though they are rated lower (3600 lumen older version Squadron) than the HID's in output the LED light actually goes where I want it and is brighter and more usable on the trail.
http://www.ddmtuning.com/Product-Cat...-Kits-Lighting
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 screwed with this post 05-20-2014 at 03:31 PM
catalina38 is offline   Reply With Quote
Old 05-20-2014, 04:02 PM   #9
srad600
srad600's Avatar
Oddometer: 674
Have you looked into the LED bulbs that have recently come out? I have one in my 990 and the light output is substantial. I've combined that with the AUX led lights and it feels like I can turn the sun back on at will...
It's being sold by a vendor and fellow 9X0 rider, check out the thread here. http://advrider.com/forums/showthread.php?t=948701
BAJA 2014 - 990s
srad600 is offline   Reply With Quote
Old 05-20-2014, 11:45 PM   #10
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,479
I had HID fitted and eventually the headlight reflector lost its silver coating. I've gone back to halogen in the low beam, and HID high beam combined with some extra LEDs.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 05-21-2014, 05:04 AM   #11
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,018
+1. I'm buying that as soon as the wife gets over the last credit card bill.
Orangecicle is offline   Reply With Quote
Old 05-21-2014, 06:29 AM   #12
RoundOz
Plenty of seasoning
Oddometer: 1,014
The good and the bad
I am on my 4th iteration of lighting improvement with a 990. Unless your standards are a lot lower than mine I think fighting the dot headlight shell will be a losing battle. Some guys have had acceptable success with the european light and hids. That seemed to me to be a lot of money, especially when some (not all) were complaining that the reflector was degrading after a short time. Though I dont always practice what I preach I feel the only place for a hid is in a projector lamp. The change in focus leads to glare that I am always concerned about and dipping my lights early for in order to avoid blinding other road users.
I also run a pair of Rigid driving lights and am very impressed with the output but again, find that I dim them earlier than I would like and the difference from high beam with drivers to low beam (Morimoto projector with 35 watt hid) is way too great, leaving me night-blind to a certain extent.
Still under construction....a pair of Hella 90mm lamps....one reflector for the hb and a bihalogen projector with hid for the low. I might go back to having a dimmer on the Rigids for when I am on the highway in traffic.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 05-21-2014, 07:30 AM   #13
Jbone11 11 OP
Jbone11 11's Avatar
Oddometer: 739
Cool...those look like they might do the job....at least for the stock headlight. Price isn't too bad either.
I picked up a brighter halogen on the way home from work last night and it is 'brighter adn whiter' but only by about 20%...if that. It was the mid range H4 and was cheap so I figured I'd try it out. I'll definitely look into that LED bulb though!
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
Times are GMT -7.   It's 12:28 AM.
