Old 05-21-2014, 02:14 PM   #1
dogsdangles OP
Oddometer: 14
Question 990A overheats right away!
I've read about the notorious overheating issues with the stock bikes (fans come on too late to cool the engine), but I'm having a different issue: my fans come on when the temperature gauge is at about 50%, and then I start boiling over coolant! This happened to me on a 55 F day after riding less than two miles on the first ride of the day.
Any thoughts on this? I'm guessing that perhaps something in the cooling circuit is clogged? Coolant not circulating or something?
dogsdangles is offline   Reply With Quote
Old 05-21-2014, 02:35 PM   #2
wsmc99
wsmc99's Avatar
Oddometer: 495
Radiator cap.
They fail and do this to the cooling capacity.
wsmc99 is offline   Reply With Quote
Old 05-21-2014, 03:17 PM   #3
travelsomewhere
Oddometer: 159
burp the air from the system too
2009 KTM 990 ADV
travelsomewhere is offline   Reply With Quote
Old 05-21-2014, 04:39 PM   #4
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
Originally Posted by wsmc99 View Post
Radiator cap.
^^^This^^^
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-21-2014, 04:46 PM   #5
dogsdangles OP
Oddometer: 14
Radiator cap.
Thanks, wsmc99, Alleycatdad. I'll take a look at this, but wouldn't I have noticed a coolant leak if the cap had failed? The only coolant leak I had was via the overfull drain on the reservoir when it overheated.
Old 05-21-2014, 05:05 PM   #6
Alleycatdad
Oddometer: 1,440
Nope. When the cap fails it allows the coolant to "boil over" into the overflow tank. Btdt.
SA
Old 05-29-2014, 07:06 PM   #7
dogsdangles OP
Oddometer: 14
So I received my shiny new radiator cap, and started the procedure in the manual for bleeding the cooling system. I raised the front of the bike, took off the radiator cap, and unscrewed the bleed screw. Instead of the coolant level in the radiator dropping, as soon as I took out the bleed screw, coolant came spewing out of the radiator cap port!
Any thoughts on this? I know I need to add fluid to the radiator, but it cannot be filled any more than it already is. I ran the bike for about 5-10 minutes (I should have timed it, but didn't) until 6 temperature bars were illuminated, then I turned the bike off. I'm now waiting for a while for the engine to cool to see if I can add more fluid.
On the plus side, no coolant came out of the overfill tube this time!
Old 05-30-2014, 02:10 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,176
Temp should go up, in order to open the valve and allow circulation to the radiator
This will allow the air to move from the engine tunnels to the radiator and rad cap, while the bike has the front wheel up high. Squeezing the thick hose at the LHS would also help. Mind the hot coolant overflowing from the rad cap or the bleeder screw.
Cheers.
Old 05-30-2014, 02:34 PM   #9
Bighat
Oddometer: 43
Had the same thing happened radiator cap was bad need to clean off corrosion where the rubber gasket meets the radiator... Problem solved
Bighat is offline   Reply With Quote
Old 05-31-2014, 02:27 PM   #10
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
Even if it appears to be full to the top of the radiator, still burp it before cleaning the seating area on the radiator and fitting the new cap.
I can do it by myself. With the bike on the centre stand, lift it up by the throttle side handlebar until it balances on the back wheel and the left leg of the centre stand. You can then rock it around the balance point and see the radiator level drop as the trapped air comes out.
If its a real bad case of trapped air, after removing the radiator cap, loosen the waterpump bleed screw first, let the air come out there, then burp the radiator.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
