Old 05-29-2014, 05:53 PM   #1
Superflyj OP
Superflyj's Avatar
Oddometer: 56
Zumo 550 Parts needed. Where to buy?
I have a Zumo 550 and cradle. 2 problems.
1) No screws to mount cradle to RAM mount. Can't find them online. Anyone know where to get them?
2) The power cable that came with it was previously in a 1200 GSA and my F700GS does not have the same kind of, actually no type of connector. Any solutions for hardwiring to the battery -> cradle?
Jeff
Draper, UT
2013 F700GS
Superflyj is offline   Reply With Quote
Old 05-29-2014, 07:30 PM   #2
ADVer
ADVer's Avatar
Oddometer: 198
Can't help you with #1 although they are pretty standard bolts that should be available at most hardware stores.
As far as number two, if it has the plug from the 1200 you may have the right connector hidden by your battery.
Check out the details and pictures here to see if you do.
http://f800riders.org/forum/showthre...e-on-my-F800GS
ADVer
ADVer is offline   Reply With Quote
Old 05-30-2014, 03:52 AM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,011
1) Your local hardware store
2) You don't mention what kind of connector is attached, but you can cut off whatever is there and mount it via the connector of your choice, or take it straight to the battery. Just be sure to put in a fuse on the positive lead. The manual, availalble online from Garmin, should have the wiring diagram.
dunno.....
Old 06-04-2014, 11:43 AM   #4
Superflyj OP
Superflyj's Avatar
Oddometer: 56
Yep!
Thanks guys! I'm a tard. I didn't get the mounting thing until I saw some photos.
Connector, yes! The cradle has the big white square one. The F700GS has that?? Bikes at home, need to look.
Thank you!
Jeff
Draper, UT
2013 F700GS
HTML code is Off
Times are GMT -7.   It's 06:26 AM.
