Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 05-31-2014, 04:46 PM   #1
phme910 OP
Oddometer: 87
Accurate speedometer on the 1190 ADV R??
Today when I was riding I noticed a 15KM/HR difference between the speed on the KTM versus that of my Garmin Zumo 660.
The bike speedometer was showing faster.
So which is the accurate one?
Has anyone had issues with proper speed display on the 1190?
thanks
phme910 is offline   Reply With Quote
Old 05-31-2014, 06:08 PM   #2
SCflyer
SCflyer's Avatar
Oddometer: 1,642
thanks
Everyone R and standard has app. 5% difference between indicated and "actual". I asked my dealer, he called his tech guy and was told it is what it is. Liability issues and such.
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 05-31-2014, 11:01 PM   #3
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 774
I'd go with the GPS. I have noticed a similar discrepancy between my 1190R and my Garmin 665.
A ride you say? When and Where?
My Favorite Pics
Todd-Squad is offline   Reply With Quote
Old 06-01-2014, 04:42 AM   #4
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,427
Mine seems to be a bit more than 5%. Last nite was my first ride since I bought it and rode it home in April. IIRC 65 "indicated" was 60-ish on the GPS. And obviously the faster you go the worse the error. Very similar to my Jap bikes. I thnk the only moto I've ever had with an accurate speedo was my Softtail Custom, and I think my Speed Triple is pretty close. I don't understand the "liability" issue, but I've heard it for years. And now that I'm thinking about it, my 990 SMR is pretty close, the front tire circumference shows on the speedo and I've heard that it can be re-programmed - but the stock setting is about right for a "half worn" 120/70.
What I want to check today is how accurate the odometer is.
PineyMountainRacing is offline   Reply With Quote
Old 06-01-2014, 04:49 AM   #5
MrEndo
MrEndo's Avatar
Oddometer: 421
Can u set the tire size in the speedo to 19? This has worked on my 640 and 950. You should see a 21 come on when u turn on the ignition. The older speedos could be changed by owner. I dont know about the newer ones. U might have to have the dealer reset it.
2015 Harley Ultra Limited
2013 350 EXC-F (Wife's)
2008 530 EXC-R/2008 Beta Rev4T
2006 950 Adv S/2002 640 Adv/1970 Yamaha RT1
MrEndo is offline   Reply With Quote
Old 06-01-2014, 05:11 AM   #6
PineyMountainRacing
Oops....
Oddometer: 2,427
I'm going to swing by Carolina KTM tomorrow while I'm out running around and have Scott enable my TPMS. I'll ask him about the speedo on the 1190. I know older KTMs the owner could change the settings for the front tire, and on my 990 SMR (2011) I believe the dealer can change it, but I have no idea on the 1190. I bought mine in April but had to leave it in NC when I flew back to FL. It's been frustrating not having the bike available to check things as I read these threads. The good part is now I'm back in. NC and have 9 days to ride and work my way home to FL
Old 06-01-2014, 06:10 PM   #7
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 437
There's no dealer settings such as wheel diameter to play with. There is a different ECU firmware version for the R compared with the S and other differences depending on if the 'bike has MSC, EDS etc. Wheel diameter is hard coded into the firmware released by the factory. In Australia the MSC version(s) of the firmware were recalled in March because of a coding error that resulted in inaccurate speedo readings. Apparently this was quickly fixed by KTM in a new release of the MSC versions of the firmware that came out in April. It seems very likely that all 2014 'bikes hitting the distributors prior to March 2014 had this fault. A KTM dealer can check the firmware version numbers and make sure the latest version is loaded.
KTM 1290 SA, KTM 1190R, Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 06-01-2014, 07:36 PM   #8
VonBiker
Roost Hog or Die
VonBiker's Avatar
Oddometer: 464
Speed
My 2014 1190 Std is off by 5% as well.
Just need to remember...
'98 ATK605
'07 Yam WR450F
'07 Yam XT225
'14 KTM 1190 Std.
VonBiker is offline   Reply With Quote
Old 06-01-2014, 09:19 PM   #9
NewToMe
safety 3rd
Oddometer: 1,131
Mine reads 10% high, all the time, every time.
NewToMe is offline   Reply With Quote
Old 06-02-2014, 02:24 AM   #10
FuzzyDunlop
Oddometer: 283
Same here. Shits me.
Sent from my GT-I9505 using Tapatalk
Currently riding 2013 KTM 1190 Adv R
FuzzyDunlop is offline   Reply With Quote
Old 06-02-2014, 02:46 AM   #11
2wdrift
Oddometer: 106
Originally Posted by fuzzydunlop View Post
same here. Shits me.
Sent from my gt-i9505 using tapatalk
+1
2wdrift is offline   Reply With Quote
Old 06-02-2014, 07:23 AM   #12
WickedKTM
Lost
Oddometer: 140
Originally Posted by newtome View Post
mine reads 10% high, all the time, every time.
x2
WickedKTM is offline   Reply With Quote
Old 06-02-2014, 10:35 AM   #13
VonBiker
Roost Hog or Die
VonBiker's Avatar
Oddometer: 464
High
I take it back.
Mine is 10% high! not 5%.
But this Colorado after all. It is legal to be......
'98 ATK605
'07 Yam WR450F
'07 Yam XT225
'14 KTM 1190 Std.
Old 06-02-2014, 12:43 PM   #14
SCflyer
SCflyer's Avatar
Oddometer: 1,642
Got my % and mileage thinking reversed in the initial post. I meant 10% of indicated as stated later.
Old 06-02-2014, 03:13 PM   #15
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,174
Someone posted somewhere....do not remember if it was a std or r.
They have a 2013 and updated the software to get the 2014 package.
Before update, the speedo was fine.
After update, speedo was 10% off.
Makes me think, what can be going on inside the program to throw off the speedo?
Start slow then easy off
OhBoy is offline   Reply With Quote
Times are GMT -7.   It's 05:38 AM.
