Go Back   ADVrider > Riding > Mapping & Navigation > GPS 101 - Which GPS For Me
Old 06-02-2014, 12:20 PM   #1
amk OP
Oddometer: 498
BaseCamp does not see maps
BaseCamp 4.3.1 does not see Topo Canada V.4
All worked well on other comps under Win32 OSes (XP & Win7), now under Win7 64 it only shows global map or nothing.
How to fix than without running XP mode on Win7?
amk is offline   Reply With Quote
Old 06-10-2014, 12:57 PM   #2
Jisei
Jisei's Avatar
Oddometer: 32
Same Here
Having same problem. Maps show on device but BaseCamp doesn't recognize. Garmin Support says to install maps onto device only through the MapInstaller application. I think i am going to ditch Garmin maps altogether. Went to redownload one of the preinstalled maps and I missed the one year cut-off buy a few days. Need to buy a new map now. Bullshit. Installing OSM maps now but they don't do topi.
Jisei is offline   Reply With Quote
Old 06-10-2014, 01:08 PM   #3
Bleemus
Oddometer: 1,138
Download and install Garmin Express from their site. I actually had 2010 maps with no purchase and it updated my Nuvi software and installed 2015.10 maps for some unknown reason. I am not calling to complain!
Bleemus is offline   Reply With Quote
Old 06-10-2014, 02:12 PM   #4
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,933
Use Javawa Device Manager to enable gps map visibility in Basecamp.
Emmbeedee is online now   Reply With Quote
Old 06-10-2014, 06:12 PM   #5
Jisei
Jisei's Avatar
Oddometer: 32
[QUOTE=Emmbeedee;24364143]Use Javawa Device Manager to enable gps map visibility in Basecamp.
Many thanks. That little gem did the trick.
Old 06-10-2014, 07:24 PM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,933
It's a great program.
Old 06-10-2014, 08:04 PM   #7
Jisei
Jisei's Avatar
Oddometer: 32
Yeah, it really is a great tool.
I've reset my Montana to the default settings and I'm starting from scratch. Got rid of my OSM's ( but they're really quite good). Your tutorials were what pushed me towards the Montana in the first place...a wealth of knowledge. It just has some annoying aspects...no doubt due in large part to not knowing the ins and outs and not willing to spend the hours digesting it. Here is an example....I have a short cut to my home on the main menu screen. When I use it I get thrown out of my default profile and into automotive. Not a big deal but wtf!
Old 06-10-2014, 08:13 PM   #8
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,933
You just need to take that option out of the shortcut you created. My Montana's tied up with a map update or I'd look into it for you, but your shortcut is only doing what is built into it.
And yes, OSM maps are great. I have a complete set of Canada on my Montana and 78S with a profile for each.
Emmbeedee screwed with this post 06-10-2014 at 08:31 PM
Old 06-10-2014, 09:08 PM   #9
Jisei
Jisei's Avatar
Oddometer: 32
I had no idea I had to edit the shortcut's properties. You would think it would stay in the profile you were using at the time you used the shortcut. Thanks for pointing me in the right direction. That was always pissing me off.
Old 06-11-2014, 05:46 AM   #10
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,933
It's not that you "have to". It's that you can. Garmin probably thinks that using CNNA will be the best map for the purpose but it's good that you have the option to change that shortcut.
Go to Setup, Shortcuts, choose the shortcut, then "Edit" and you'll see this screen:
If you choose the "Profile" setting you can tell it to stay in the current profile by choosing "None" at the top.
Old 06-11-2014, 11:48 AM   #11
Jisei
Jisei's Avatar
Oddometer: 32
Thanks for the tutorial. I was going to change all the settings on auto profile but now I will edit the shortcut as you have shown...cheers for that.
HTML code is Off
Times are GMT -7.   It's 09:53 AM.
